Anyone have ideas on how to convert a voltage into a resistance?
I searched around, but found only digital solutions, looking for something analogue. Thanks. |
#2 |
a FET transistor maybe?
kind of converts gate-to-source voltage to drain-to-source resistance but it is very unlinear what do you need it for? |
#3 |
Voltage controlled attenuator or Voltage controlled amplifier,
Related post: Would this work as a volume control???
SivanandBalan |
#4 |
Search the internet for 'light dependent resistors' or 'LDR'. This is a special kind of resistors whose value change depending on how much light intensity they are receiving
Also there are LDR + LED combos in a single package perfectly isolated from ambient light, they are sometimes used in the limiter sections of PA amplifiers, altough these parts are hard to find The smartest feature of LDRs is that no electrical connection between the resistor part and the light-emitting part is required |
#5 |
EVA !! The post was for Voltage depended resistor as discribed by darkfenriz, not Light depended resistor.
SivanandBalan |
#6 |
The LDR is a resistor the value of which can be controlled by the current through the LED inside. It is not difficult to convert a voltage to a varying current through an LED. I think it is a good suggestion.
We use Vactrol LDRs in guitar amps all the time. They serve as signal routing switches and as tremolo interfacecs. Google Vactrol and you ought to find them easy enough. Or make your own. Photoresistor and a light bulb wraped up in something light tight. Drive the bulb with your voltage and the resistance of hte photocell varies. |
#7 |
Thanks for the ideas! I did find some info about optocouplers (same thing as the ldr + led I guess) previously, I'll look into it in more detail.
Here's a brief description of exactly what I'm trying to do. I used to have a potentiometer that drove a gauge. But now I want to replace the potentiometer with a Hall effect rotary sensor (these have come down in price alot recently). The Hall effect sensor outputs a voltage. The gauge is an industry standard gauge that is driven by a variable resistance. I cannot change the gauge. The voltge to resistance conversions does need to be linear for a good reading on the gauge. Thanks again for the ideas. |
#8 | |
Electrons are yellow and more is better!
What was this gauge for and what was the resistance controlling? Why do I ask? Maybe you can use a voltage or a current to control?
/Per-Anders (my first name) or P-A as my friends call me |
#9 |
you might check the display spec more closely, if it isn't poteniometric (voltage sensing) then it almost certainly responds to current drawn by the sense resistor from a fixed voltage, you could just put in(or sink) a voltage controlled current
a very few circuits might use a resistor to control an internal oscillator and use a frequency counter type display i missed the part about this being about solid state audio amplifiers however |
#10 |
He wants us to Amplify on his situation. Once he has Solid advice his State of mind will improve.
| Convert Krell 300iL to European voltage | brianboru | Solid State | 346 | 23rd December 2011 12:40 PM |
| Any way to convert Denon DVD-5900 voltage 110 to 220V? | Gadget King | Digital Source | 0 | 30th July 2009 02:24 PM |
| ??Convert Voltage from 220 to 100 for Meridian 200 Transport?? | Gman111 | Digital Source | 0 | 2nd April 2008 07:44 PM |
| resistance | impsick | Solid State | 7 | 28th May 2007 04:41 PM |
| Convert voltage Pass Labs XA 100 from 110v to 220v | LucaF | Pass Labs | 2 | 28th March 2007 01:38 PM |
| Page generated in 0.11085 seconds (79.57% PHP - 20.43% MySQL) with 10 queries |
