jFET input ,full symmetrical class A circuit
Old 25th July 2002, 04:16 PM   #11
promitheus is offline promitheus  Europe
promitheus's Avatar
Yeah why not?
If Kevin is a member here and can share some extra info on this design it would be a great help .
I donīt know what name Kevin uses in this forum at all but any idea would be great.
Old 25th July 2002, 06:31 PM   #12
paulb is offline paulb  Canada
I believe the name he uses is "kevin gilmore". Unless that's somebody else.
Old 25th July 2002, 06:54 PM   #13
Jocko Homo is offline Jocko Homo  United States
Banned
It is based on having done this many times, over many years.
You can put a capacitor across the load resistor. A JFET of BJT follower after it would be a good idea. (Actually.....you will need a few more parts to bias the whole thing up......and as they liked to say in college...."the solution is left to the reader as homework....".)
Borbley's version has too much stuff, and he mucks it up with feedback, as I recall.
I have some ideas on making a differential output circuit using only one DAC. At >$33 each for a '1704, using a total of 4 seems too expensive. However, it is still in the idea stage, as I have more pressing problems.
Like no job.....and thanks to crooks like Bernie Ebbers.....no retirement fund anymore....., so it may be some time yet before I get back to it.
Jocko
Old 25th July 2002, 09:09 PM   #14
morsel is offline morsel
morsel's Avatar
Kevin Gilmore's amp is outstanding just the way it is. Reducing the number of output BJTs will increase the output impedance and is not a good idea. The DC servo is an excellent, noninvasive method of protecting the output from DC at the input. Since it integrates the output signal to produce a bias voltage to correct DC offset, there is no reason to use a discrete circuit in place of the opamp.
Old 26th July 2002, 11:35 AM   #15
promitheus's Avatar
Hello ,
Jocko Homo I was looking at Nelson Passī design which uses two 610 MosFETs only. Do you know this design from his DAC in the passlabs site ?
the link is here:
http://www.passlabs.com/pdf/d1-srv-man.pdf
Old 27th July 2002, 06:33 PM   #16
Banned
That works fine, and a good place to start. My idea is more convoluted.
Jocko
Old 27th July 2002, 08:59 PM   #17
promitheus's Avatar
I thought this circuit wouldnīt work for me because I thought it was balanced and a one circuit.
After you saying about a capacitor across the load at the outptut of the DAC I rechecked Nelsonīs DAC and saw that it was 2 independant circuits, one for every phase.
I think the filter is in the input, I am still not sure how it works and how the volume works. It also has caps in the output which I dont know if they are supposed to be there. If the Circuit has DC at the output than I will need to use those.
I like it because it is simple.
Old 27th July 2002, 10:21 PM   #18
promitheus's Avatar
I am really sorry I made a mistake here.
You canīt see it at first but the two parts are connected through the volume control.
Strange volume control.
I wouldnīt know how to make something like this for unbalanced signal.
The input IS a common gate mosfets configuration, but I think the filter is at 20 KHz only for CD use.
Old 28th July 2002, 12:13 AM   #19
rickpt is offline rickpt  Portugal
rickpt's Avatar
Thumbs up I/V stage
I think what you want is something like this one...
I found it on the tweaker's asylum...
Here is the link: http://www.audioasylum.com/audio/twe...ges/57022.html
I hate mosfet's but some guys like them, you can change them if you want...
Rick
Old 28th July 2002, 12:16 AM   #20
rickpt's Avatar
Cool pic
sorry
jFET input ,full symmetrical class A circuitHide this!Advertise here!
Jfet input for Aleph 60? Dansk Pass Labs 14 22nd January 2011 02:34 PM
discrete jfet input opamp rubydac Solid State 5 12th March 2008 05:59 PM
JFET input SuSy Chipamp Russ White Pass Labs 4 7th May 2007 09:12 AM
JFET in-circuit matching Leolabs Solid State 5 9th April 2006 02:44 PM
Symmetrical input stage hjelm Solid State 19 22nd April 2004 01:37 PM
Copyright ©1999-2017 diyAudio
