Old 15th December 2004, 10:28 PM   #1
Default AA1800 bias resistors
Does anyone know which bias resistors go bad in the Heath AA1800 amp? This makes the channel output level vary. It looks like the two 3.3k 2w resistors. Are there any others that go bad?
Thanks Ed
Old 16th December 2004, 07:56 AM   #2
destroyer X's Avatar
Default If you have the schematic, will be easier to help you
Try to put, at least a partial schematic, in special the bias portion.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 20th January 2005, 03:21 PM   #3
rrcrain is offline rrcrain  United States
Any of the carbon resistors can go bad, but none have to date in the two amps I own. Perhaps I'm just luck so far. I do need to start searching for replacement electrolytics in the amsp in any event. Those puppies have a limited lifetime at best and it's best to replace them before they fail.
Bias Protection Resistors in DC Coupled Amp dsavitsk Tubes / Valves 6 23rd August 2009 01:53 AM
Bias Supply resistors AmpBuilder225 Tubes / Valves 14 19th April 2009 12:34 AM
400A, emitter resistors and bias: I would learn Mywing Pass Labs 6 5th June 2008 04:19 PM
Push-Pull Cathode Bias Resistors Kashmire Tubes / Valves 5 6th January 2008 07:38 PM
quick bias tolerance question...across source resistors Mattyo5 Solid State 6 12th October 2003 11:09 AM
Page generated in 0.05369 seconds (79.50% PHP - 20.50% MySQL) with 10 queries
