I have a small problem with my hifi which i hope you can help with. I use my computer sound card to decode DVD's. Its a £200 card so the quality is not as poor as you would think. The only problem is that the sound level it produced is pathetic. I have a 200w rms per channel amplifier and the sound level produced is not at a level i require! I need to make a cut down preamp, no volume contoller no input selector just the low level amplification. I have two questions: A) what is the item i wish to make called? B) Does anyone know how to make one? I
#2 |
Hmm... reading this a second time (the first time I thought you meant it was too loud... I know it is at my house!)
What you are looking for is a little pre-amp circuit to give you some gain. Do you know or can you measure the following? -- the sensitivity of your power amplifier (that is, the signal level that when input will give you the maximum output) -- the maximum output level of your sound card? -- the input impedance of your amp. (If its low, perhaps the selected output from your card wasn't able to drive it well)
Would a woodchuck bother to chuck MDF? |
#3 |
Hi Peter,
in the picture below you have the schematic of a simple 2 channel preamp with gain=11, supplied by a standard wall wart (DC 15V/0,3A). You can duplicate the schematic as many times as needed (for example, if you need 5 channels, you should make 3 copies). This preamp can be built, say, in a small plastic case on a veroboard (to keep things as simple as they can get). Regards, Milan |
| amp reverse.. | Professor smith | Solid State | 29 | 11th June 2009 03:16 PM |
| WTB: 10K reverse Log Pots!!! | Minion | Swap Meet | 0 | 17th December 2006 07:10 PM |
| help me reverse engineer this sub | epalla | Subwoofers | 21 | 21st July 2006 09:44 PM |
| Page generated in 0.14411 seconds (60.25% PHP - 39.75% MySQL) with 11 queries |
