Old 13th December 2004, 07:25 PM   #21
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Are you willing to mention the kind of bipolars before we are sitting under the Christmas tree ?
Looks like Sponge Bob has killed another thread.
Old 13th December 2004, 08:14 PM   #22
DRC is offline DRC  United Kingdom
DRC's Avatar
Default Did you consider ...
andrew (anli),
you rejected single ended OP's due to their low efficiency. Did you consider the case of single ended with active current sources (aleph / aleph-x) and their improved efficiency ?
dave
Old 13th December 2004, 08:41 PM   #23
anli is offline anli  Russian Federation
Default Re: Did you consider ...
Originally posted by DRC
andrew (anli),
dave
Dave,
Is it possible to point to the schematics variant you are talking about?
Andrew
Old 14th December 2004, 02:04 PM   #24
DRC's Avatar
Andrew,
All of the aleph series amplifiers use a 'load current sensing' active current sinks (ie they are not constant current) - I think that is what 'aleph' is intended to refer to.
As you asked about bridge load amps :
Aleph-X
If I recall correctly (?), the gain of the 'current source(s)' is ~x1.5 so the peak load current is somewhat higher the standing current would suggest (and the current in the other CS decreases at the same time).
As I see it - it is more efficient than a true bridge load, constant current, single ended amp.
dave
Old 14th December 2004, 02:40 PM   #25
dave
Agree. But I prefer:
- to exclude capacitors from signal chains,
- use a push-pull topology to reduce demands to power supplier.
There are different shcools (is this word appropriate here? :-) how to
design. One of them - to use fewer (but expensive) parts. At this case
audio quality depends on, as example, concrete capacitors models
at very high degree. And I go to by a next capacitor to replace the old one,
then - next, and so on. One day, I see the last capacitor cost is about the
whole amplifier cost :-) You see, I overdraw the reality :-) I just want to say,
it is more interesting to me to resolve the problems schematically.
Both ways are good: each scool has nice realisation examples.
It's matter of taste, I think.
Andrew
Old 14th December 2004, 04:29 PM   #26
DRC's Avatar
Andrew, I agree with you on the issue of expensive components - I do not think it is money well spent and prefer to use low cost parts myself (preferable the ones in my junkbox)
Slightly off topic (sorry, no MOSFET's and not even a complete / tested design !!!), here is my own take on an "aleph-X like" amp using very low cost components :
Daves amp !
I went for a SE design as I could see no benefit in the complexity of push-pull, when using a bridge-load design, as source & sink are fully symmetric. BTW, my current source works like a differential current generator (i hope !) and should produce 'optimum' efficiency.
I am interested in why you made push-pull and bridge-load a requirement ???
dave
Old 14th December 2004, 05:01 PM   #27
Daves amp !
dave
I need some time to understand your project and to read that thread.
As for push-pull - the topology seem to be much more tolerant of PS pulsation,
I think.
Andrew
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
Alpine PDX class D for home audio use? keith89 Class D 2 17th January 2008 07:32 PM
higher power class T for outdoor home theatre draizinbrew Class D 2 24th October 2006 07:58 PM
Home home or pop pop noise from sub ricky fong Multi-Way 0 26th February 2003 01:15 AM
Class-A/Pass with home theatre Gabster Pass Labs 13 21st September 2002 08:19 AM
Page generated in 0.10101 seconds (76.56% PHP - 23.44% MySQL) with 10 queries
