Old 14th December 2004, 06:22 AM   #21
djdamix is offline djdamix  France
Originally posted by Upupa Epops
Hi David, you see distortion, because peak driving current in negative halfperiode is low ( only a few mA ). Colector load of VAS must be bootstraped or as currrent source.
I try that and you are right, seems are better now I have less distortion on negative halfperiode. I've also solve my DC problem (bad transistor). With the extra stage (IRF 610 & IRF9610) , I get about 50Khz "clean" bandwith with three output pairs. I'll had some more and rise the voltage. But before I must get a MPS42 to replace the MJE15031 with can't stand the voltage.
David
Old 14th December 2004, 08:24 AM   #22
in fact I'll try to get a MJ15035 (350V) instead of an MPSA92
Old 12th February 2005, 10:15 PM   #23
tmblack is offline tmblack  United Kingdom
Anyone try to use a small MOSFET for the VAS?
I orrdered some MJE15032/33 to replace the old one that blew.
But I got a small enhancement type VP0808 and wonder if there is any reason not to try it if bias can be set up correctly?
Tom
Old 13th February 2005, 07:44 AM   #24
sajti is offline sajti  Hungary
And what do you think about the local feedback in the VAS? The local feedback reduce the distortion, and the output impedance, without very large overall feedback.
sajti
Old 13th February 2005, 08:51 AM   #25
Did it Himself
richie00boy's Avatar
Give the MOSFET a try. The only major issue is to make sure that it's capacitance is low so that it doesn't load down the diff pair. I have thought about using a MOSFET for that position before as it would allow me to run the VAS at a relatively high current thus drive several output MOSFETs directly.
I always use degeneration on the VAS to linearise it, I think it's good to have local feedback at every stage and then just a little overall loop feedback is required.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 13th February 2005, 09:58 AM   #26
I think to use parallel voltage feedback. I attached the schematics, I planned. The R11 and R12 do this feedback.
sajti
Old 13th February 2005, 11:51 AM   #27
Did it Himself
Nice. Should R5 and R8 be there though?
Old 13th February 2005, 12:54 PM   #28
The R5, and R8 set the bias current for the input transistors. The gain of the VAS is about R11/R6 or R12/R7. With this values, the result is about 33.
sajti
Improving DC-servos Elvee Solid State 22 16th September 2008 11:04 AM
Help me improving my pre-amp! thanh Solid State 0 26th January 2007 10:08 AM
Improving Heatsinks freo Solid State 7 13th March 2006 11:11 AM
improving the Mcintosh C22 Craig405 Tubes / Valves 22 13th July 2005 11:36 PM
improving ic's eg jrc4556d awpagan Digital Source 2 7th January 2005 06:50 AM
Page generated in 0.10237 seconds (78.59% PHP - 21.41% MySQL) with 11 queries
