I have a B&K ST202+ that I would like to add a pair of filter caps to.
Would it be OK to add 2 different values? The stock caps are 14.5K and the ones I would like to add are 100K. I tested it tonight and I was very please with the sonic results. Should I completely remove the old caps? Also, the new caps are 63v, and the rails measure 64v. Am I asking for trouble, or would this be OK? Thanks, Matt |
#2 |
Personally I would use 75v caps here. Your dc voltage also has some ripple, so peak volts will be higher than the 64v you've just measured. What happens when the mains voltage goes up? Leakage on an electrolytic goes up as voltage rises towards rated volts. Based on those 3 criteria (& some others) some designers will use even higher rated caps. The life of the caps is finite and running them at or over their rated voltage may seriously reduce their lifetime. regards Andrew T. |
#3 |
Hi Matt,
I agree with everything Andrew has mentioned. I would add that much higher capacitance is not good. Why not just replace the old caps with new (not surplus) caps around the same value? Your rectifiers are not rated for the high peak current that the units you have will cause. -Chris |
#4 |
Try to install many small caps.
I own a HK citation 16 . It have 4 can 10000UF. I put 1000uf, 470uf, 47 uf in paralel with those big 10000 uf. WOWWW what a result!!!! hearing is beliving A friend of mine explain to me that larger can are good for base but they are slower for mid or high.....The smaller cap are much faster and they "fine tune" the filtration. I know it is PFM but try it...it cost only 10$ for 12 caps for my DIY mod happy x-mas coyote |
| Adding Z to Protect Amp (newbie question)? | diesel_88 | Multi-Way | 4 | 25th January 2008 05:05 PM |
| adding caps and snubber network to LM3875 power board | quickshift | Power Supplies | 0 | 19th August 2005 02:12 PM |
| Guitar Amp Question!!!!! Adding Film Cap? | zxx123 | Tubes / Valves | 11 | 29th March 2005 01:50 AM |
| Digital Data Inversion And Adding Question. | mrfeedback | Digital Source | 11 | 28th May 2003 01:33 PM |
| Adding large caps? | Rino odorico | Everything Else | 6 | 13th September 2002 10:16 PM |
| Page generated in 0.07736 seconds (72.16% PHP - 27.84% MySQL) with 10 queries |
