#11 |
The adj pin current results from the operation of the regulator, it is not something *you* need to do anything on. As an example, if you take the simplest regulator, a transistor, where you put Vin to the collector and take Vout from the emitter, the Vou is set by the base voltage. There will always be a small base current to ground, and that is equivalent to the adj pin current. Now, in this example the base current of course heavily depends on the load current, but in the more sophisticated (internally) '317, this is almost constant. This current, going through the bottom resistor of the divider setting Vout, causes a voltage rise on the adj pin and therefor upsets the simple equation that says the Vout is depending on the R1/R2 ratio only. The larger the resistors, the larger the error for the same Iadj.
The minimum load current is something else, in the above simple example it would be the minimum current drawn from the emitter for correct operation. This minimum current doesn't run from the adj pin, but from the Vout pin to ground. Of course, you *can* make R1/R2 so low in value that the current through them is the minimum current, but normally the load current should be sufficient for that. Jan Didden
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! |
#12 |
That was very helpful Jan!
Edit: I just thought, what happens if you set the resistor at such a high value that the Base to Ground current is below the minimum that's specified in the regulator's datasheet? Does it cause the 'Base' to start collecting a negative charge? |
#13 |
I fogot to ask. The output voltage of the regulator is very high, over 400V. I'm trying to keep to SMD parts for the board. This makes using Tantalum beads and even a lot of electrolytics tricky. I've found one series of electrolytics that are about 10V over the maximum of the regulator, a bit risky.
Ceramics seem to be coming to the front for the output capacitor. I can manage about 1 - 2uF maximum of ceramic capacitance at the regulators output. The electrolytics are also only available on special order. I know a lot of people dislike electrolytics, how do ceramics compare? |
#14 | |
Did it Himself
| Pooge 5.51 positive regulator | audiodoc | Solid State | 22 | 8th March 2012 01:14 PM |
| Why positive rail only?? | Leolabs | Solid State | 0 | 18th March 2008 01:59 AM |
| LTP w/ positive only supply | arnoldc | Tubes / Valves | 10 | 24th May 2007 02:32 PM |
| Both Secondaries for Positive Voltage? | Stocker | Parts | 3 | 27th May 2004 11:37 AM |
| Positive regulators for negative supplies? | JohnG | Solid State | 7 | 4th February 2003 12:28 PM |
