Vbe Multiplier Help Please
Old 6th December 2004, 05:45 PM   #1
mefistofelez is offline mefistofelez
Default Vbe Multiplier Help Please
I have been trying to understand PMA’s amplifier introduced here: http://www.diyaudio.com/forums/showt...543&highlight=
I have a problem with a Vbe multiplier disclosed by Nelson Pass in his patent: US3,995,228. To achieve bias voltage Vb = 9 V, with 2*Vbe = 1.4 V, the equation to be solved is:
(R1+R2+R3)/R2 = Vb/2*Vbe
Setting R1=R3= 600 Ohm, R2 = 543 Ohm
Looking at the schematics: web.telecom.cz/macura/pm_ab_er1.gif , the resistor R7 - corresponding to R2 - is 10 kOhm.
Now, interestingly enough, simulation confirms the value 10kOhm.
Any help would be appreciated.
M
Old 6th December 2004, 05:55 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
By your own formula, you would expect the middle resistor R2
to be about 200 ohms, this of course reflecting a simple
Vbe multiplier with two complementary devices and three resistors
Old 6th December 2004, 06:14 PM   #3
Nelson wrote:
"By your own formula, you would expect the middle resistor R2
Vbe multiplier with two complementary devices and three resistors."
I have made a mistake, the value of 2*Vbe = 2.8 V ( I have a BE junction in series with a diode).
However, it still does not explain the discrepancy.
M
Vbe Multiplier Help PleaseHide this!Advertise here!
optimizing the VBE multiplier hienrich Solid State 80 29th November 2010 10:25 PM
VBE multiplier fglabach Solid State 23 12th June 2009 04:56 AM
Vbe multiplier - bypass cap Donk Solid State 7 22nd January 2008 01:55 AM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Multiplier car amp Kilowatt Solid State 19 7th September 2002 02:40 PM
