Some power amp designs eliminate the capacitor in the series feedback path because a good quality capacitor in this critical position needs to have a large value and can therefore be expensive. A DC servo is then used to control the DC offset voltage at the output.
A friend of mine has used the circuit below many years ago. It allows the use of a smaller capacitor (C1) which can then be MKP or similar. R3 must be much smaller than R2 to get a good -3 db at low frequencies. For this reason the circuit works best with FET's in the diff amp. However, useful LF extension can be achieved with BJT's in the diff amp if they are matched and R1 and R2 are precision resistors. While tweaking a Sony TAF-444ESX amp I noticed that it uses this circuit with a a dual JFET input pair. The capacitor was formed by two 47uF Muse elctrolytics connected in non-polar mode. Although the caps were inside the feedback loop, sound quality still improved when I replaced it with a 10u polycarbonate. I wonder why this circuit is not used more often since it can eliminate that dreaded electrolytic cap in the feedback circuit. Does anybody have experience with this circuit? |
#2 |
If not cost, I don't know why anyone would put an electrolitic in the signal or feedback path to begin with. They typically sound sour. Is there any other reason?
#3 |
Almost everyone puts an electrolytic in the feedback loop. The reason is that it is cheap and effective. Servos, properly designed, are better. Some extreme friends of mine, choose to direct couple, without servos, and live with the voltage drift on the output. This is not easy, most of the time.
#4 |
The schematic appears to show a DC gain of about x51 and an AC gain of about x1001. Am I correct? If so then the amp will generate large DC offsets due to small dc on the input. regards Andrew T. |
#5 |
To calculate AC gain short C1:
AC_GAIN=((R2//R3)+R4)/R4, it is about 51 To calculate DC gain remove C1: It is then a unity gain voltage follower if the input is applied at R1, howeever the usual DC decoupling cap C2 prevents DC response. At DC R3 in series with R4 acts as an output load. R1=R2 minimizes ofsett voltages. |
#6 | |
Electrons are yellow and more is better!
but you have two breakpoints, the last one gives you gain of 1.
/Per-Anders (my first name) or P-A as my friends call me |
#7 |
LTSpice Simulation using an op-amp model with input decoupling omitted
The 3-db freq is at 7.8 Hz for the component values posted. For a JFET input stage R1 and R2 can be increased to 1M to give a -3 db freq of 0,78 Hz. To improve the low freq cut-off for a BJT input pair R1 and R2 can be increased, but output offset may become an issue. An alternative is to lower R3 and R4. If power dissipation becomes an issue, resistors can be paralleled. |
#8 |
thanks for explaining the gain. Q how do you calculate the time constants? Q is it a 2 pole bass roll off with staggered freqencies? regards Andrew T. |
#9 |
One of Rod Elliot's articles, perhaps the most recent, discusses the subject. He based it on some SPICE simulations. His conclusion (I won't try to summarize the agument) was that the elimination of this cap can have unpleasant/unfortunate results when certain events occur in the input source.
I don't know enough to say if he is right or wrong, but I think anyone contemplating yanking the cap should at least check it out. |
#10 | |
To make border freq. lower should be used bigger resistors, which makes it unable to use in bipolar differential stage. |
| feedback loop | rmenger | Instruments and Amps | 4 | 21st October 2006 07:04 PM |
| feedback loop | rmenger | Parts | 0 | 29th July 2004 01:24 PM |
| Zen V4 Feedback Loop Extension | dcmohs | Pass Labs | 1 | 14th March 2003 05:35 PM |
| ZEN V4 without feedback loop | Selfmade | Pass Labs | 8 | 20th February 2003 03:38 PM |
| Feedback Loop help | KevinLee | Solid State | 4 | 1st December 2002 01:39 AM |
| Page generated in 0.11805 seconds (78.72% PHP - 21.28% MySQL) with 11 queries |
