Old 1st December 2004, 03:38 PM   #1
larryg is offline larryg  United States
larryg's Avatar
Default leach amp dc off-set
i have my new leach amp up and running. bias is set to 100ma.
in checking the dc off-set the left ch. measures .030 and the right
ch. measures .054. i did not match the transistors or the zener
diodes. is this difference normal? any help will be greatfully appreciated.
larryg
Old 1st December 2004, 04:07 PM   #2
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Hello,
30-50mV is ok for DC
\Jens
Old 1st December 2004, 04:33 PM   #3
larryg's Avatar
thanks Jen Rasmussen!
larryg
Old 1st December 2004, 04:53 PM   #4
acenovelty's Avatar
Mornin,
If you're really concerned about this small difference, take a look at D 13,14,15,16. D13 & 14 need to match D 15,16 fairly close.
From the Leach page,
"The bias currents in the diff amps are regulated by zener diodes. In each diff amp, two 20 V diodes are used in series to form an equivalent 40 V zener. Although a single diode could be used, the error tolerance is less when two diodes are used in series. I prefer to measure the zener voltage of each and pick series combinations of diodes that give equal reference voltages on each circuit board. It is not necessary to have exactly +40 V and -40 V. But the two voltages on each circuit board should be as close as possible to minimize dc offset problems.
The zener voltage of a diode can easily be measured by connecting a resistor in series with it on an electronic breadboard and connecting a bench power supply across the series combination. The power supply voltage should be set so that the current through the diode is 3.3 mA. If you don't have a current meter, the voltage across the resistor should measure 3.3 x R, where R is in kohms. For example, the voltage across a 2 kohm should be 6.6 V. Once the current is set, the dc voltage across the zener diode can be measured with a voltmeter. For example, if you have +15 V and -15 V supplies, connect the diode in series with a 3 kohm resistor across the two outputs and measure the diode voltage. If you get the diode backward, the resistor will get hot."
And a big hurrah getting it up and running. Playing any real music yet? Folks will be happy to see your pics.
Prosit
Two people can keep a secret if one of them is dead.
Old 1st December 2004, 06:29 PM   #5
larryg's Avatar
thanks acenovelty! looks like good info to me! yes i have been
listenning to the amp! tryed it this morning for the first time.
man was i happy!! hope to post pics soon.
larryg
My Leach Amp Clone (LEACH 150) panson_hk Solid State 28 15th August 2011 08:12 PM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
anyone have leach PCB? ilyash Group Buys 2 7th September 2007 10:36 AM
Leach Superamp vs Leach 4.5 Samuel Jayaraj Solid State 4 26th October 2002 09:20 AM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 10:16 PM
Page generated in 0.08387 seconds (73.04% PHP - 26.96% MySQL) with 10 queries
