Old 1st December 2004, 01:53 AM   #1
diyAudio Moderator Emeritus
Default Crossover distortion
When I read about theories of output stages, they say that classB (and AB) power amp suffers a "Crossover distortion". With my limited knowledge, I accept it as happening when NPN and PNP output stages will be 1=on and the other =off. The transition between on and off causing this crossover distortion.
I assume this happens because each transistor will be off and on. If we can make all transistor never off (like classA), maybe this crossover distortion will dissappear. (Is this right?)
I'm looking for a way to always have both transistor on. Someone said there is a patent on "never turning off" in class (A)B, but I couldn't find it. Does anyone know where it is?
I think about this drawing that I attached. This is complementary EF output stage. If I put D1 and D2 after emitors, before output, and put 10mA CCS to rails, this way both T1 and T2 will never turn off, minimum will always have to pass 10mA in every condition.
I have question about this idea.
1. T1 and T2 will never turn off. But can this idea eliminate crossover distortion in class(A)B amp?
2. But it makes the D1 and D2 conducting/not conducting. Does diodes in this mode gives another kind of on/off distortion? If it gives "diode distortion" that is worse than "transistor distortion" then this idea is not good.
3. If this idea is working, what kind of diode is suitable for D1 and D2? Ordinary diode/Schottky/Fast recovery/Soft recovery?
Old 1st December 2004, 04:50 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Diode reverse recovery and turn-on delay, by themselves, are much worse than crossover distortion. Schottky diodes may be an interesting option
Old 1st December 2004, 05:23 AM   #3
Steven is offline Steven  Netherlands
Steven's Avatar
Default Re: Crossover distortion
http://www.diyaudio.com/forums/showt...339#post282339
S.Tanaka, "New Biasing Circuit for Class B Operation," JAES, 1981, Vol. 29, No 3, p. 148 (patented)
Nelson Pass: patent # 3,995,228
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 1st December 2004, 05:25 AM   #4
Steven's Avatar
Before I forget, also the Hawksford error correction circuit does not switch off the output transistors.
Steven
Old 1st December 2004, 08:43 AM   #5
Hi, Steven,
Thanks for the link. You also think the same too (but for classA?)
Do you have a small JPG on this patent?
Old 1st December 2004, 08:49 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
I have done similar experiments and I got real nasty crossover distortion => not a good idea
/Per-Anders (my first name) or P-A as my friends call me
Old 1st December 2004, 09:15 AM   #7
uli is offline uli  Austria
Source: www.passdiy.com
www.passlabs.com
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 1st December 2004, 01:20 PM   #8
=> not a good idea
Thanks for the input.
I see passdiy and passlab website, but couldn't find patents by Mr.Pass.
Where can I see all his audio patents?
Threshold series amps are marvelous in this area. Many kind of amp, with different cct, but same purpose. NP incorporated EC like cct, but he says its not for EC. Now I know what they was intended. To eliminate Xover distortion.
Old 1st December 2004, 05:15 PM   #9
darkfenriz's Avatar
What is so-called class AA?
I heard that Technics used it
Old 1st December 2004, 05:42 PM   #10
Steven's Avatar
Hi, Steven,
Type the patent number in here: http://patft.uspto.gov/netahtml/srchnum.htm
or look here: http://l2.espacenet.com/espacenet/vi...b&LG=en&DB=EPD
Steven
Crossover distortion - be gone! Circlotron Solid State 4 24th August 2009 12:09 PM
Help New TAC US 12A crossover distortion. spirod Solid State 1 9th February 2008 03:34 PM
So, what does crossover distortion sound like? beedlo Solid State 16 24th January 2005 12:29 PM
Crossover Distortion? Killjoy99 Multi-Way 8 30th March 2004 05:10 AM
Sensitivity to crossover distortion angel Everything Else 3 26th January 2004 02:33 AM
Page generated in 0.11632 seconds (78.30% PHP - 21.70% MySQL) with 11 queries
