Old 29th November 2004, 08:16 PM   #1
hegestratos's Avatar
Send a message via ICQ to hegestratos Send a message via AIM to hegestratos Send a message via MSN to hegestratos
Default ADC for relay volume control?
I recently got my hands on 50 Siemens small signal DPDT relays (V23042), so I want to build an 8-bit relay based volume control. I've read some threads of people building simple systems with a pot and an ADC, or more complicated systems with a ucontroller. I'd like to go for the simple pot+ADC, but I'm wondering about the ADC - I hear the popular ADC0804 (such as used in the Aleph P) is unstable above the 6th bit. I'd like to use 8 bits, since I have the relays. Any recommendations?
Alfred
Old 29th November 2004, 08:23 PM   #2
mcs is offline mcs  Denmark
Why not just use an absolute encoder? There's no reason to use an ADC, as far as I can see.
A microcontroller circuit doesn't have to bee complicated BTW. I have just made this board - only two chips (microcontroller and relay driver).
And third, why 8 relays? I use 6 relays (for 64 1dB steps), which I think is more than enough.
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 30th November 2004, 01:01 AM   #3
TwoSpoons's Avatar
I would definitely go for the microcontroller approach. You can do so much more with a bit of software. And hooking up a micro is simpler than using a seperate ADC + glue logic.
e.g. auto mute when changeing source, monitor heatsink temp and wind back the volume if it gets too hot, and my favourite which I thought of today is the parental lock - volume limit for when little Johnny is home alone with your stereo
Old 17th January 2005, 08:38 AM   #4
kiyull is offline kiyull  South Korea
Default 12 bit ICL7109
I am testing with 12 bit ICL7109(use only upper 8 bit), which is very stable dual slope integration DAC.
Kiyull
Old 17th January 2005, 12:11 PM   #5
jackinnj's Avatar
you shouldn't have any problems with the ADC0804 if you bypass the power supply pins and pay even somewhat careful attention to signal routing -- if Vcc or Vref is noisy you will have problems -- about 5 years ago I made and sold some ADC boards using the chip -- I used a LM4041 as VRef -- I did not use separate digital and analog grounds.
Old 17th January 2005, 12:34 PM   #6
Sorry to all for going slightly off topic.
Mikkel, can you update your website with the 6 relay version.
Can this be used as a multi channel volume (for outputs of digital filter) control in active speakers?
Is it possible for one microcontroller to serve 6 channels?
regards Andrew T.
Old 17th January 2005, 10:06 PM   #7
Yes, I thought about that. This should work, but there's still a possibility that you will happen to set the pot so that the output will oscillate between two values. Since you're not using the 4 least significant bits, the chance of it happening is just 16 times lower.
I didn't have any problems with the ADC0804 itself in my test setup. But no matter how you wire the circuit, there's always going to be an input voltage where the ADC jumps from one output value to the next. If you happen apply that voltage, the output will oscillate. Obviously, if you reduce the noise in the system, you'll have to be closer to the exact voltage, but it will still happen. Not using the n least significant bits will reduce the odds of it happening by a factor of 2^n.
Needless to say, I'm going for a microprocessor now. I'm aiming at a 7-bit volume control with mute.
Alfred
Old 17th January 2005, 11:39 PM   #8
With a modest AVR and an endless directional knob (encoder) this could be done.
The ATMEGAS have built in ADC/DAC and control for dallas 1 wire devices. Were talkin a few dollars worth of silicon and a few hours programming. The ULN relay drivers cost as much as the ATMEGA.... but then again you guys have parts bins full of transistors.
Bill
relay volume control cubezone Chip Amps 14 3rd May 2007 07:12 AM
relay volume control - POP! wayne325 Pass Labs 22 26th August 2006 01:58 AM
Remote relay volume control kit. harvardian Swap Meet 1168 15th September 2004 07:07 PM
Relay Volume Control for BLS promitheus Pass Labs 60 10th May 2004 06:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
