heat sink problem
heat sink problem
Old 24th March 2006, 04:04 AM   #11
CBS240 is offline CBS240  United States
CBS240's Avatar
Simple question to revive an old thread... I understand that bronze can be used as a heat sink material, but what about brass. I salvaged some brass plates, about 15" X 8" and are 1/2" thick. Probably 60/40 brass is my guess as they were cut out on a press. Still, quite heavy though. I would like to affix fins to it from some scrap 3" square aluminum tubing I have lying around, and use a fan. Would this work?
All the trouble I've ever been in started out as fun......
Old 24th March 2006, 04:51 AM   #12
Workhorse is offline Workhorse
Workhorse's Avatar
Hi Carlos_ S A N T A N A,
you were simply amazing!
Old 24th March 2006, 07:34 AM   #13
AndrewT is online now AndrewT  Scotland
brass is much worse than copper for heat conduction.
Check to find how it compares to aluminium.
For blown use the fins can and should be very close together.
About 8 to 10mm for unblown and 1 to 3mm for blown.
You need a thickness to fin height of about 1 to 10 for aluminium fins.
Attach all the aluminium to the back plate with heatsink compound (messy).
What about corrosion? Will this interfere with the conduction interface?
regards Andrew T.
heat sink problemHide this!Advertise here!
my heat sink picture space2000 Solid State 37 20th July 2008 08:59 AM
heat sink for UCD700? pburke Class D 68 7th July 2006 04:40 AM
Required heat sink troystg Chip Amps 9 15th November 2004 01:40 AM
Yet another heat sink problem OliverD Pass Labs 10 16th October 2003 05:29 AM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 05:23 AM
Copyright ©1999-2017 diyAudio
