Old 27th November 2004, 06:25 PM   #1
Abe is offline Abe  United Kingdom
Unhappy Parasound HCA-3500 USA to UK power supply
I have a HCA-3500 and I would like to change the input voltage to 240v. I have seen that some Parasound amps have this ability built in like the HCA-1206 which was manufactured at the same time as the HCA-3500.
Does anybody know how to go about this?
I have seen the method for the HCA-1206 and this is pretty straight forward but no luck for the HCA-3500.
Old 27th November 2004, 09:40 PM   #2
glen65 is offline glen65  United States
Default 240 volt conversion not option on this model
Here is a link to their site for the owners manual if
you want to check for yourself.
http://www.parasound.com/service_inf...rsmanuals.html
Old 28th November 2004, 07:22 PM   #3
I know the Parasound web site does not describe any method of simple switches or wire swapping but I have a friend who can do all the work for me I just need to to know what needs swapping and where to get the components from. At the moment I have a step down running it but at 3000VA it has trouble if the voltage supply to the house dips below 240V as 13amps at 240V gives 3120VA but when the voltage dips to 220V which it can often 13.64amps of current kills the fuse and changing the fuse 4 times a week is getting a bit silly. I have thought of hard wiring the step down to its own 15amp MCB but this isn't an ideal situation.
Old 28th November 2004, 08:51 PM   #4
Whether or not you can convert it internally is going to depend
on the power transformer. If the one they are using has two idenical primary windings connected in parallel "Which is
the case with the hca-1206" then its just a matter of changing
it to a series hookup then going to a smaller fuse. However
if the primary has only one winding you wont be able to convert it in this manner.
Good Luck
Old 29th November 2004, 06:56 AM   #5
Sounds like a challenge. So it looks like I'm gonna crack this baby open and see what damage I can do and what ever I do I'm gonna have to do twice cos it's got two.
How hard could it possibly be?
Any more advise will be greatly appreciated, and I'll let you know how it goes.
Parasound HCA 2003 3 channel power amp doerfast Swap Meet 0 22nd March 2009 10:49 PM
FS: Parasound HCA-1000 THX 2-CH Power Amp mrdon Swap Meet 1 27th January 2009 02:39 AM
Parasound Classic 2125 power amp question crippledchicken Solid State 0 6th April 2008 11:29 PM
Parasound HCA-500 Amp and Power Supply Board john65b Swap Meet 0 4th February 2007 05:34 PM
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 0 8th April 2006 07:29 AM
Page generated in 0.07764 seconds (72.92% PHP - 27.08% MySQL) with 10 queries
