| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hey guys,
I wanna build another amp.. I've built a subwoofer amp from "scratch" before from stuff I had around the workshop,and a schematic of a car amp I copied. Prolly about 150W output...then I finally blew it up while fiddling with the output stage. This time I've got a buncha parts from a Sansui amp I've had for a while (A-1130p) 2 x 130W It gives me grief whenever I try to fix it..So I gutted it a bit,and want to rebuild it..(reuse the chassis,and some of the parts.) Heres what I have... 450VA/350W power tranny,secondaries 47-0-47 and 16-0-16 Vac. And 2x 8200uf 80V caps.. (I think the rails were about +/- 70v at idle.) Output transistors are 2SC2581 / 2SA1106 Drivers for outputs are 2SC2591 / 2SA1111 I have a bit of an output circuit worked up around those (copied from the Sansui.) But I'm willing to change it a bit.. The Sansui originally used a STK3102 for the front end,and I think,had somekind of bias servo circuit. I guess I really just need a suitable circuit for the front end,or a schematic of a complete amp that will work with the parts I have here.. Can anyone suggest a circuit to follow? I have this stuff available for the rest of the circuit.. ECG/NTE 373/374's ECG/NTE 323 2SC1815/2SA1015(?) 2SA733 2SA777 2SC458 2SC711 2SC1345 2SC1509 2SC1684 I also have lots of other parts floating around the workshop..Boxes of stuff I havn't even looked through yet,who knows what might pop up! I already found a buncha TO-3 transistors,and 10 pairs of MJ15011/15012!,so I should be set for parts,I just need a suitable circuit for the parts I have available.. Later on those MJ15011/12's might make thier way into a couple of Leach amps...or maybe one big monoblock! Thanks guys! Any suggestions would be great.
#2 |
Okay,so I'm leaning towards the ESP 3a,using the parts I have on hand..
http://sound.westhost.com/project3a.htm But, It looks like my +/- rails are gonna be a bit (2x) higher at 65-70Vdc,instead of the 35V (42V max) specified on the ESP page..I know the output,and driver transistors I have will handle the voltage,what about Q1,2,3,4,9? Does anybody know off-hand if any of the transistors above will survive the higher rails before I go digging through datasheets? Is there anything else I should change because of the higher voltage? Maybe someone knows of a ~100W amp schematic with 60-70V rails I could follow instead? |
#3 |
From my understanding your tranny has two different secondarie voltages? one being 16 and the other 47?
If so you should Gut the whole thing and build a new shiny preamp and amp into it. No idea which one though Just my limited input
#4 | ||
![]() Quote:
| Thread Tools | |
| I wanna build a CHEAP mono tube amp, need advice.... | camusmuse | Tubes / Valves | 12 | 5th June 2008 12:35 AM |
| Any F4 PCBs left for a new wanna-build-one? | giacomo_pagani | Pass Labs | 8 | 13th May 2008 12:06 AM |
| Just wanna say something | shaunly | Multi-Way | 2 | 13th November 2004 07:15 PM |
| i wanna build me a bass amp | badger | Solid State | 10 | 27th December 2001 03:02 AM |
| Page generated in 0.15837312 seconds (82.09% PHP - 17.91% MySQL) with 10 queries |
