Im building a pre-amp PSU and i'm using 2 off 75VA laminated transformers with 24-0-24v secondaries and half wave rectification.
I have a couple of 15,000uf caps but would think that is to much for the relativly small transformers. I'm considering either a pair of 4700 or 6800uf caps, does this seem about right? I've looked on the net to try and find any advice on transformer size in regard to capacitor size but didnt come up with anything. TIA, Paul. |
#2 |
You might want to try a few 1000uF caps in parallel as they are cheaper and have lower series resistance all together than single larger caps will. Also, bypass your diode bridge with small film caps in parallel with the diodes.
If it sounds good... it is good! |
#3 | |
- Hannu |
#4 |
Did it Himself
Firstly I have to ask why you are only halfwave rectifying not full. Fullwave will give you less ripple for a given size cap.
As for cap size, it won't hurt to have as big a cap as you can get. |
#5 |
I'm building a Naim style PSU, hence the halfwave rectification.
See here for layout. If the output from the caps are identical I want to try hanging just the single reg from the caps to make a totaly mono supply. Paul. |
#6 | |
Well, I for one can't figure out how to calculate the optimal snubber values. I get lost in the math every time I read that paper. Isn't there another place where it is explained in a better way? |
#7 | |
#8 | |
- Hannu |
#9 |
Why? Yes, it takes a while to fill 15,000uFd. But once filled, they don't impose any extra load on the transformer. I have a box with 15,000uFd fed from a 24VA core, has been running happy for 25 years. And my motto has always been what Richie says: "it won't hurt to have as big a cap as you can get." Over-capping does raise peak current. Peak current depends a little on load, but for low-ripple supplies it depends much more on series resistance, which depends on transformer rating. Rectifiers should never be less than transformer rated current, plus 2 to 5 multiplier safety margin. Your 1.5A windings suggest 3A to 7.5A rectifiers, and go higher when you have big caps. Since 15A is cheap in plain silicon, I'd go that high. Yes, even if you only really need 0.1A to the load. If you like exotic rectifiers, cost and reliability are something to ponder. If you do like the idea of dozens of smaller caps, split them up as C-R-C. 3,000uFd, 1 ohm, 12,000uFd. This helps clean some of the rectifier spikes from the supply rails. While I understand the point Hagerman makes, and have seen it, personally I like brute-force cleaning rather than specific tricks, at least in my own DIY. But there are many ways to skin cats. 75VA seems like a lot for a preamp. I confess I've done similar over-kill. |
#10 |
Thank you for the reply's, even if some of them were WAAAYYYYY over my head!!
I will use the pair of 15000uf caps that i've already got and see how I get on with them. Have any of you had any experiance of pairing up the regs? Im using Avondale TPR's so it is possible to trim the outputs to match each other. The idea is that I can end up with a dedicated mono PSU for each rail, all be it at some cost in space and cash! Paul. |
| The size of electrolytic capacitors? | roger-k | Pass Labs | 36 | 14th September 2008 08:07 PM |
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| what size capacitors to use? | mgriff | Power Supplies | 6 | 16th August 2006 11:04 AM |
| Speaker size v Room size | cliffy | Multi-Way | 6 | 19th February 2005 08:34 AM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 01:29 AM |
| Page generated in 0.12507 seconds (84.81% PHP - 15.19% MySQL) with 10 queries |
