Old 18th July 2002, 12:53 AM   #11
Account Disabled
Send a message via ICQ to gromanswe Send a message via AIM to gromanswe Send a message via Yahoo to gromanswe
Default is turntable RCA
Then she can't use a XLR-RCA adapter, can she?
There is only problem when 2 are different.
But I am unsure of which is which
Old 18th July 2002, 01:29 AM   #12
Send a message via AIM to nania
gromanswe
She did use the aforementioned adapter and I think she disconnected the ground fork at the turntable. If anybody knows how to pinout this oddbal configuration, post it on this thread.
Old 18th July 2002, 01:58 AM   #13
Account Disabled
Default So her Amp have RCA input?
I would use a RCA-RCA adapter
Old 18th July 2002, 06:09 AM   #14
frugal-phile(tm)
planet10's Avatar
Default Re: So her Amp have RCA input?
In your situation for surrounds i'd run long speaker wire.
On the other topics that have come up:
I run about 4m of single ended cable from my pre-amp to my active crossovers with no problems. When my new pre-amp arrives and i get it built, and when i get my new XO designed and built i will be switching to balanced. I'd also like to wire my turntable with balanced/differential output to get the max out of the new pre.
Why does the lady with the TT want XLRs? Does she want to run it differential (ie two connectors) or does she just want a single plug?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th July 2002, 12:54 PM   #15
Her phono stage has XLR (balanced) inputs and her turntable has the conductors (wires) listed above. I just need to identify the pinout to put an XLR connector on the turntable so that it can connect to the phono stage (preamp) XLR input.
Old 18th July 2002, 05:14 PM   #16
frugal-phile(tm)
planet10's Avatar
A pair of XLR inputs for balanced. The pre-amp manual should have the pin-out or contact the manufacturer or pop the top.
If the arm is wired with a common ground -- The cart hot goes to the non-inverted input, ground to ground and the inverted input is left floating.
If there are seperate grounds you can take them (separatly) to the inverted input and leave the ground unconnected.
dave
Long speaker cables ctong Pass Labs 30 13th January 2010 06:44 PM
Speaker level to line level converters qguy Subwoofers 2 9th December 2007 03:58 PM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
Can I use speaker wire for line level? joe carrow Everything Else 5 29th April 2007 09:58 PM
diy speaker to line level converter zobsky Parts 1 24th September 2006 05:31 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
