can I run 2 torroid in parallel operation?
Old 21st November 2004, 09:55 PM   #1
ericpeters is offline ericpeters  Netherlands
ericpeters's Avatar
Default can I run 2 torroid in parallel operation?
I want to increase, actually double, the size of the transformer in one of my DIY amps.
Can I add another identical transformer and run both parallel.
if so does 2* 500 VA have the same characteristics as one 1000VA?
Old 21st November 2004, 10:31 PM   #2
quasi is offline quasi  Australia
quasi's Avatar
Provided the transformers are identical then it should be ok. Watch the phasing though.
As far as characteristics go, the 1000va would probably have slightly better regulation at full power than 2 x 500va.
If your amp is stereo, then another (better) alternative would be to run 2 discreet supplies for each channel. This means another bridge and more capacitors but this would be a better setup.
Cheers
Old 21st November 2004, 11:03 PM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Giving each its own rectifier bridge will minimize
mismatch difficulties.
Old 21st November 2004, 11:48 PM   #4
dulel is offline dulel  Yugoslavia
Do not parallel transformers. Slightly voltage mismatch will cause large currents to flow through transformer windings, due to low winding resistance. This will happen without any transformer load.
Old 22nd November 2004, 05:11 AM   #5
quasi's Avatar
Default Hi Dulel;
I have run identical transformers in parallel a few times before without any problem.
The DC resistance of the secondary is not as relevant as the AC impedance of the secondary. A slight (and I mean slight) voltage difference across the impedance of the other secondary does not result in a large current draw, if of course the phasing is correct. You can try this by putting a small 50hz (60 hz) voltage across the secondary of an unconnected mains transformer and noting the current drawn. You will find it to be very little.
One way to check it would be to measure the current drawn by each primary before and after the paralleling. If the current drawn by each primary stays the same (or negligible change) then no problem.
I doubt there would be more than a few watts wasted. At the end of the day I guess it's all a question of economics.
Cheers & Beers
Old 22nd November 2004, 08:38 AM   #6
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Maybe Sphinx did a bad thing with its Project Sixteen hybrid Class A amplifier.
Rated at 100 watts Class A at any load from 2-4-6-8 ohm.
With 4 toroidal tranformers, relay-switcheable parallel or series secundaries.
The only of their series with a switcheable powersupply, for some the only one that sounded really good.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 23rd November 2004, 12:41 AM   #7
Default Re: Hi Dulel;
[QUOTE]Originally posted by quasi
[The DC resistance of the secondary is not as relevant as the AC impedance of the secondary. A slight (and I mean slight) voltage difference across the impedance of the other secondary does not result in a large current draw, if of course the phasing is correct. You can try this by putting a small 50hz (60 hz) voltage across the secondary of an unconnected mains transformer and noting the current drawn. You will find it to be very little.
Sorry but your example is not valid.
If you disconnect primary winding, then you can apply anything up to nominal voltage to its secondary and current will be low.
term "AC impedance" you probably use for impedance of magnetizing inductance. it is usefull for calculating magnetizing current which is only a small part of nominal current, and can be ignored almost always.
once magnetizing current is ignored transformer can be modelled as a pure ressistive element, thus secondary current will be voltage difference divided by the sum of both windings resistancies (DC), and can be large as I said before.
In my opinion only bifilar windings of one transformer can be paralleled safely.
Greetings,
Old 23rd November 2004, 01:37 AM   #8
quasi's Avatar
Default Hi Dulel
Yes Dulel I agree with you. My analysis was incorrect because as you say it only dealt with an unloaded impedance.
In the real world (well my world anyway) paralleling identical transformers has not caused me any problems. If there are any, they are so small that I have not noticed any performance compromises. I.e. I have not noticed any abnormal temperature rise or execessive primary current being drawn to indicate a loading by one of the secondaries.
Cheers
Old 23rd November 2004, 01:50 AM   #9
paulb is offline paulb  Canada
It seems fine to parallel, I'm doing it now for a Class-A amp I'm building and haven't had any problems. Others in this forum have reported similar success. I am using low-valued resistors (0.47 ohm) in series with each secondary winding to help them share the load.
If you're worried, follow Nelson's advice and use a bridge rectifier per transformer and parallel their outputs. As long as the transformers are the same, they should provide roughly equal currents, but the rectifiers will prevent any reverse current from flowing back into one of the transformers.
Old 23rd November 2004, 01:32 PM   #10
Some are even more worried, and use a rectifier for each secondary winding !
can I run 2 torroid in parallel operation?Hide this!Advertise here!
How much to pay for torroid in UK? andyburlow Chip Amps 6 22nd March 2009 07:11 PM
Parallel operation of triodes. ashok Tubes / Valves 9 14th June 2008 09:43 PM
1800VA Torroid to get 40A??? Dominick22 Chip Amps 26 18th July 2006 09:36 AM
Q on torroid mounting weinstro Power Supplies 3 25th January 2006 01:22 AM
small crack in torroid!!future of torroid? sagarverma Power Supplies 24 8th November 2005 05:22 PM
Copyright ©1999-2017 diyAudio
