Hafler DH 200 problem
Old 21st November 2004, 04:35 PM   #1
guy_b_g is offline guy_b_g  United States
Default Hafler DH 200 problem
I recently bought a DH-200 on ebay.
Not knowing anything about these amps I hooked it up and ran it.
The yellow overheat light comes on at startup, but I didn't know that it was problem indicator.
Both channels work, and the amp doesn't get hot (in fact, it runs much ccoler than my Perreaux does at the same volume levels).
The sound is terrible, very thin and flat in the high end/upper mid- range, and hiss.
The amp runs quiet with no input.
Any help would be appreciated!
Thanks!
Old 22nd November 2004, 01:09 AM   #2
Dick West is offline Dick West  United States
Well, you have a way to go as your description defies logic.
Get a copy of the manual from Hafler.com. Remove the lid by taking out the top 4 sheet metal screws on both sides and loosen the remaining 4 a little bit on one heat sink to make it a little "wobbly." Then, remove the lid.
Be careful of the charge in the large filter caps. It can be lethal.
Trace the wiring and compare it to the diagram in the manual. You are correct, the yellow light should not come on ulnless the thermal switch becomes hot. I suppose the switch could be defective or stuck ON.
Get a VOM and check each channel separately for DC offset and the bias setting. The manual will tell you how to do it these things. Check this thread as it should help:
http://www.diyaudio.com/forums/showt...643#post465643
Check all the fuses to make sure they are OK and are of the proper value.
Once you have checked out all these items post back here with your results.
Good luck
Dick
Hafler DH 200 problemHide this!Advertise here!
Hafler DH 500 problem confused dh500 Solid State 16 8th October 2016 06:02 AM
Hafler TA1100 problem vfluxrob Chip Amps 7 31st December 2009 04:17 AM
Hafler Five Hundred problem hatrack71 Solid State 4 10th June 2009 01:38 PM
hafler xl-280 problem zerohead_ak47 Solid State 2 28th December 2008 07:41 AM
Help!!! Hafler se240 problem Z-Ya Later Solid State 6 11th September 2008 03:08 AM
Copyright ©1999-2017 diyAudio
