A friend has a Arcam delta 90.2 which is about 15 years old (he thinks) It has recently developed a problem which he explains as follows :-
"Symptom is that it sounds like the base is blown, it starts crackling at any more than background volume" The problem is only the right channel. Does anyone hav any info on this amp or any idea what the problem might be and if its fixable? Thanks. |
#2 |
A bit more info about this amp, the amp is producing sound from both channels, however the right channel is very crackly with very distorted bass.
I got him to take the cover off and he could not see anything obvious, no scorching, no bulging caps no smell of burning.... Any ideas of how to work outs what's wrong? |
#3 |
Last try, anyone know about this amp?
Any ideas where I can get schematic? Thanks. |
#4 |
Hi wytco0,
I don't know this amp specifically, but general troubleshooting may help here. Run an oscillator into the input and watch the level on the output. There may be a capacitor opening up that is causing the distortion at low frequencies. 6 and 10V electrolytics are a good place to look for this. Another place to look is the solder joints on the heavier components on the PCB. Just resolder them as cracks can be almost invisable. -Chris |
#5 |
Ask Arcam directly for the schematic. In most cases they will oblige - they have excellent support and aftercare
#6 |
Anatech, Thanks
jaycee, Thanks also, I see your from Norwich, I am from Costessey although I doint live there most of the time. |
#7 |
Actually I am from Liverpool but recently moved to Norwich with my girlfriend
#8 |
Hi wytco0,
Do you have any way of testing the unit? Oscillator (or CD with tones) 'scope or decent meter? Many units are repaired without any documents. -Chris |
#9 |
jaycee, well you have chosen ' A fine city' hope your enjoying it there, I think its a great place.
anatech, not yet but I am slowly getting hold of bits of test equipment, I should be able to borrow something soon. |
| Arcam Delta 290 | lduarte1973 | Solid State | 2 | 28th February 2009 09:06 AM |
| Arcam Delta 70/70.2 | FibCouple | Digital Source | 2 | 12th January 2008 11:42 PM |
| Arcam Delta 290 problems | MGriffiths | Solid State | 1 | 24th April 2007 12:54 PM |
| Delta 290 Arcam | mike salway | Solid State | 0 | 17th September 2005 03:03 PM |
| Arcam Delta 70.2 | Rotellian | Digital Source | 2 | 16th January 2004 10:33 PM |
| Page generated in 0.07784 seconds (84.33% PHP - 15.67% MySQL) with 10 queries |
