quiescent current different on both channels?
Old 20th November 2004, 04:36 PM   #1
crippledchicken is offline crippledchicken  United States
crippledchicken's Avatar
Default quiescent current different on both channels?
hi, have dual 0.22 ohm 5 watt emitter resisters when measuring voltage across outside legs on one dual i get about 8 to 10 mv. about 30 seconds after turning amp on but, across the other dual, i get between 18 to 20 mv. could it take more warm up time for one channels quiescent current to build and stabilize, than the other normally? or do i have a problem? i have no trim pots to adjust amp seems to sound fine. any help is greatly appreaciated, crippledchicken ps this in in an onkyo m-282 2 channel power amp.
Old 20th November 2004, 05:02 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
What do you mean by "other dual"? Same channel or other channel? Or are both duals in the same channel?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 20th November 2004, 05:05 PM   #3
it's for the othre channel i guess there's only two of them
Old 20th November 2004, 05:18 PM   #4
Panelhead is offline Panelhead
Default Re: quiescent current different on both channels?
This just indicates the parts are not matched. If the parts are matched to start with the current draw should be close.
Sometimes aging will cause drift, but not double current flow through a circuit.
Like you have noticed, the matching is more of a feel good type of thing. I have measured differences like that and not been able to hear it.
If it really bothers you, try swapping out to get matched parts.
George
Old 20th November 2004, 05:42 PM   #5
jan.didden's Avatar
Two of WHAT? Is this a quiz or what? Sorry, solve your stuff yourself.
Jan Didden
Old 20th November 2004, 08:10 PM   #6
TWO DUAL, RESISTORS YOU KNOW? TWO LITTLE WHITE SQUARE COMPONENTS WITH THREE LEGS PER SQUARE. ONE OUTSIDE LEG GOES TO NPN OUTPUT EMITTER AND THE OTHER OUTSIDE LEG GOES TO THE PNP OUTPUT EMITTER ON SAME CHANNEL AND, THE OTHER CHANNEL IS DONE THE SAME WAY. i want to thank you, for your polite help george. don't think i deserved the quiz remarks though as i treat everyone with respect unless, provoked! oh well, i guess some people don't know what mutual respect is. crippledchicken
Old 21st November 2004, 02:55 AM   #7
Default Re: Re: quiescent current different on both channels?
George
hi george, well i was wrong about not having trim pots. when i added the extra ps caps, i covered the trim pots he he. i removed the pots and installed the better multi turn type trimmers and rebiased and it's much better now. thats what happens when i don't pay attention i guess plus, this darn diabetes plays tricks on my eyes sometimes. reguards, crippledchicken
quiescent current different on both channels?Hide this!Advertise here!
Quiescent current question? thanks crippledchicken Solid State 29 18th June 2005 09:58 PM
LM3886 Quiescent current NITRO Chip Amps 4 20th April 2005 10:06 PM
P3a No quiescent current! PetarLD Solid State 9 17th February 2004 01:20 AM
LM3886 and it's quiescent current Toster Chip Amps 5 5th May 2003 10:23 PM
Quiescent Current JohnClark Solid State 13 16th November 2001 08:20 PM
Copyright ©1999-2017 diyAudio
