Old 19th November 2004, 09:33 PM   #1
crippledchicken's Avatar
Default measuring quiescent current of power amp question
hi, i have dual 0.22 ohm emitter resistors when i measure from both outside legs of resistor, do i divide the voltage reading by 0.22 ohms or 0.44 ohms? getting confused thanks, crippledchicken
Old 19th November 2004, 10:34 PM   #2
jaycee is offline jaycee  United Kingdom
If you are measuring over both resistors, ie the resistor legs connected to the transistors NOT the output terminal, then you should be dividing by 0.44
Old 19th November 2004, 10:57 PM   #3
hi jaycee, thanks for clearing that up for me. crippledchicken
Quiescent Current Luxman M-03 Weide Solid State 5 7th January 2012 10:33 AM
Quiescent current question? thanks crippledchicken Solid State 29 18th June 2005 09:58 PM
LM3886 Quiescent current NITRO Chip Amps 4 20th April 2005 10:06 PM
P3a No quiescent current! PetarLD Solid State 9 17th February 2004 01:20 AM
Quiescent Current JohnClark Solid State 13 16th November 2001 08:20 PM
Page generated in 0.06326 seconds (70.93% PHP - 29.07% MySQL) with 10 queries
