I`m building 2 channel amplifier to my subwoofer and
have a problem with current when amplifier is off and i turn it on. I think load current is too much for my fuses. Transformer is toroidal 230V 2x40 1200VA and there is 144000uF capasitance. input fuse is 10A slow and output fuses are 10A fast. How can i limit loadcurrent that fuses won`t burn? Please help! |
#2 |
Provided there are no problems with your setup it could be the in-rush that is blowing the fuses.
Try a soft start cct. Theres has been plenty of stuff here about that. Do a search for "soft start" or "soft turn on" Cheers
http://sites.google.com/site/quasisdiyaudiosite/ |
#3 |
Your description is kinda vauge. Are the output fuses for the output transistors that are burning too? If this is the case, your circuit may not be balancing when initially powered up, or not biasing properly as the voltage builds. You might take a measurement of the initial current in outputs. As for the input, 1200 VA would have a lot of surge current and as Quasi pointed out, a soft start circuit would work there.
| LM338 Current Limiting | imix500 | Parts | 48 | 22nd October 2009 11:21 AM |
| 12V DC/DC for amplifier. Current limiting? | Pierre | Power Supplies | 22 | 1st May 2007 11:46 AM |
| Current limiting by the PCB coil, why not? | IVX | Class D | 3 | 18th December 2005 09:08 AM |
| Page generated in 0.06898 seconds (71.10% PHP - 28.90% MySQL) with 10 queries |
