Hey all,
it's beginning winter time and thus a good opportunity to warm up one's apartement with the soldering iron... It's not that I would really need another amp (I have an Onkyo 9711 for dedicated and a Sony TA-F210 for computer-based listening), but I have both an old external drive housing big enough and this old manual from an amplifier kit that Conrad Electronic sold 15yrs ago lying around (No.196274). It's based on a couple of 2SK133/2J48 that would have to be replaced by either 2SK1058/2SJ162 or IRF530/IRF540, but anyway, is this circuit worth diying??? Most effort would be to layout the pcb which is not given in the manual. The whole kit is rated 75(55)watts/4(8)ohms at +/- 44volts - a nice size for a spare amp and not needing that big hsink. Yes, you will ask why I won't make a gainclone - but how many am I supposed to make during the long winter Note: First thing to be changed would be the nf coupling 1uF cap to some non-electrolyte type Matthias |
#2 |
Manuals first page. Maybe someone remembers it.
#3 |
Did it Himself
It's basically the industry standard Hitachi MOSFET amp circuit. Performance is perfectly acceptable, but there are quite a few upgrades that can be done. You wouldn't be able to use IRF devices unless you added a Vbe multiplier instead of just the pot for bias.
#4 |
Yeah, it looks practically identical to the Maplin MOSFET Amplifier kit they used to produce up until early 2000 when they discontinued most of their kits.
#5 |
Did it Himself
I was going to say that
PS You look like Jerry Springer |
#6 |
Hmm, well I'm no expert in construction electronics so I guess the hint concerning IRF was rather helpfull. I somewhere found them as replacement for the original trannies. I would get the first replacements I wrote easily just a few bus stops away at segor electronics so I would go with them anyway then.
Who is Jerry Springer?? But please note the Calexico poster up left. Some of the finest tunes around!!! m |
#7 |
#8 | |
Ok, I checked out Jerry. He is some 30years older than I am but has less grey hair than I have now or a better makeup!
Thanks for mentioning the application note. I found it quite fast and will work through it in a couple of days! Quote:
Thanks all for your assistance!! matthias |
| WBT Conrad MF35-151.5 | nicoch58 | Swap Meet | 1 | 4th August 2009 09:34 AM |
| Conrad Heatsinks... | EchoWars | Solid State | 8 | 15th November 2006 04:33 AM |
| Conrad Heatsinks GB in GB/EU | bremen nacht | Parts | 1 | 1st February 2006 08:48 PM |
| just got new heatsinks from Conrad | Jean | Parts | 8 | 6th June 2004 03:09 PM |
| conrad johnson help | efoda | Tubes / Valves | 3 | 24th January 2002 03:23 AM |
| Page generated in 0.09270 seconds (78.14% PHP - 21.86% MySQL) with 11 queries |
