Hello, I have an old NAD 3020. It is in great shape, but has been keep unused for many years. What are the things I should ckeck before plugging in, and what components I need to change? Should I make any mods to use it to power a pair of monitors for an home-studio?
I will be grateful. |
#2 |
Check there's nothing living in it, and the voltage across the speaker terminals is about zero at minimum volume (and no input signal).
Then fire up and see what it sounds like. I've one running all original components, sounds fine. The pots and switches will probably need a clean, IPA is OK. There's a site here with tips for replacing various caps, both in the signal path and PSU, a search of this forum will turn up IIRC the bias settings and setup method (or clicky here for the service manual) and the schematic is online in a few places. |
#3 |
Thank you for posting those links!
When you say I must check there's nothing living in it, you mean someting "organic"? |
#4 | |
) to my free space.
#5 |
Thank you! But I had already downloaded it...
#6 |
Hi
I also own a NAD 3020. Nowadays it is playing in my office. (ZEN is responsible for expelling it out of my home). I have made a couple of small changes: 1. Replaced filter capacitors: I mounted two 10,000 uF (instead of 4x2200 uF) 2. Replaced ordinary trim pots with multiturn ones. Readjusted until I got almost zero DC offset. Read this: http://www.tnt-audio.com/clinica/bias_e.html 3. Added small heatsinks on the driver transistors (this is not necessary, but I thought it to be a good idea) 4. Replaced input electrolytic caps with MKS caps. These are much bigger in size, however it is possible to mount them. 5. Cleaned all switches and potentiometers with contact spray. Hope this helps Vix |
| Another NAD 3020 | jerryo | Solid State | 17 | 3rd May 2012 06:39 PM |
| NAD 3020 amp upgrades? | TDWesty | Solid State | 59 | 11th July 2009 04:02 AM |
| NAD 3020 Which version? | xxxSilverxxx | Solid State | 2 | 3rd January 2009 09:05 PM |
| nad 3020 problems | reddish75 | Solid State | 0 | 19th May 2008 08:03 PM |
| NAD 3020 hum | rigadig | Solid State | 13 | 31st May 2004 09:33 PM |
| Page generated in 0.07957 seconds (77.23% PHP - 22.77% MySQL) with 10 queries |
