Transistor Cross Reference
Old 11th August 2009, 07:58 PM   #11
exchief92 is offline exchief92  United States
Hi Chris,
The 2SC371 was only one of the transistors taken out by a shorted output pair.
Replaced the outputs with OEM, several resistors, checked the drivers (OK), used an NTE 107 for replacement, but would prefer to use similar OEM type.
I have heard that using the 2SC945 in some audio circuits is not recommended since there is a tendency for noise.
I believe I read that on Audio Karma.
I have a 2A562 on hand I can use.
Thanks for your reply
Old 11th August 2009, 08:28 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Morgan,
False, completely false.
Perhaps the writer got some renumbered parts(=fake)? The 2SC458 was a problem device.
You're kidding me - right?
NTE107 is good for 12 VDC C-E and 25 mA for IC and 200 mW dissipation. Now get this, it's and RF transistor, so the reverse E-B voltage is only 3 VDC instead of the normal 5 ~ 7 VDC for most transistors.
How did you come to see this as a good substitute? If you used the ECG or NTE Replacement Manual, you can see why I call them "the book of lies". I'm not kidding!
No, they were the only transistors that actually failed. Some others were stressed and may fail later. The driver transistors in that channel should be replaced, as well as the bias control transistor. It was bad enough to blow a current protection transistor, so there may be more problems than you know about.
I used to do warranty service on these, and did them for years out of warranty. I'm trying to help you do a good job on this. Yank those transistors and test for gain and leakage (two modes). I'd say to simply replace them, the measuring is for your education in case something actually shows up. Leakage is in uA.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 4th April 2010, 11:20 AM   #13
Artie is offline Artie  United States
Originally Posted by Eva View Post
2SA763 [Toshiba] is also a small signal transistor :
200mW 30V 50mA
hFE=250@6V@1mA
I know this is an old thread, but you need to watch that last letter. A 763Y is 30V, but the 763W is 60V. I see the "W" version more often in audio gear.
Transistor Cross ReferenceHide this!Advertise here!
Denon AVC1A Transistor cross reference ben12345 Solid State 4 22nd February 2009 02:04 AM
cross reference or replacement mike49504 Car Audio 1 26th November 2006 08:55 AM
Cross reference for NTE234 to other types 240z4u Parts 1 8th November 2006 03:37 AM
transformer help! Marshall and crate.. cross-reference? madflower Parts 1 5th June 2005 09:11 AM
NTE Reverse Cross Reference beomuse Parts 0 14th October 2004 01:58 AM
