Münster, a diy copy with modifications of an old Sony, have some suggestions? - Page 6 - diyAudio
Old 20th November 2004, 08:21 AM   #51
destroyer X's Avatar
Default Second text part
Here is:
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 20th November 2004, 08:23 AM   #52
Default Third text part
Here is:
Old 20th November 2004, 08:24 AM   #53
Default Fourth text part
Here is:
Old 20th November 2004, 08:26 AM   #54
Default Fifth text part
Here is:
Old 20th November 2004, 08:28 AM   #55
Default The sixth part
Here is:
Old 20th November 2004, 11:36 AM   #56
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi carlos !
You are right, it's impossible to reproduce a perfect squarewave...
No mechanics is able to make such a movement !
Even electronics is not able to do this, but this is simple mathematics.
A real squarewave contains infinite high frequencies.
And for example, if you playback a 22,05khz squarewave with a
good cdplayer, guess what you get... A simple and nice sinewave !
That's because it filters out all frequencies above 22,05khz...
So the amp or tweeter will never see a squarewave, unless you
connect the amp to a signalgenerator...
Checking an amp with a squarewave is only for checking it's stability.
With a squarewave the amp easily shows it flaws and weaknesses.
In my amps i have limited slewrate to about 20v/us, that's enough to
reproduce a clean sinewave at 250khz for 20volt swing.
I could increase slewrate, but not without getting overshoots.
It seems that an amp with overshooting tends to sound bright/harsh.
Anytime i optimized my amps for not overshooting, they sounded better.
Mike
Old 20th November 2004, 12:17 PM   #57
Default Thank you MikeB, some informs i really did not knew till this moment
I thank you very much for the technical support, as i cannot go deep to explain what i mean.
But you translate to words that the more skilled guys will understand better.
regards,
Carlos
Old 20th November 2004, 06:27 PM   #58
Default Well friends, this is the Münster thread
So, as i openned a thread related to speaker problem, i will ask you, please, to go there if wanting to write something about that subject.
So, the Münster is already alive.
Also in Loudspeaker forum i openned one thread related that subject too.... there, things will have a lot of movement of peoples visiting.
Moderators, seeing too much movement, will join those threads, i expect this one, the Münster, can survive in this place.
The reason why i post the speaker matter here, is because Darkferinz made me think, so, this was made for him, that shake my mind.
I thank you Dark
Carlos
Modifications to a Plinius 8200 MKII - any suggestions as to where to start? wongstein Solid State 1 19th December 2008 07:20 AM
Modifications suggestions for The Twisted Pear Power Supplies Joshua_G Power Supplies 4 12th November 2008 11:36 PM
Ideas, suggestions, and schem to improve Sony sdpep9 es? mpmarino Digital Source 9 19th September 2008 05:21 PM
Sony copy protection & PC infection? moray james Digital Source 4 30th December 2005 07:14 AM
Sony SACD clock circuit - suggestions? dorkus Digital Source 29 26th December 2002 10:04 PM
Copyright ©1999-2017 diyAudio
