Old 15th November 2004, 03:14 PM   #1
aits is offline aits  Estonia
Send a message via AIM to aits Send a message via MSN to aits Send a message via Yahoo to aits
Default Peavey cs800 schematic
Hello from Estonia! I need the amplifer "peavey cs800) schematic.
If you find and send me I can send for you anyothers schematic or ...
Best regards,
aits.
Old 15th November 2004, 07:31 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Hi aits,
Do you want the old or the new model?
/Hugo
Old 15th November 2004, 07:53 PM   #3
dangus is offline dangus  Canada
I have a CS800 schematic dated 1990, which seems to cover amps built with boards dated between 1986 to 1989.
Old 15th November 2004, 08:08 PM   #4
Netlist's Avatar
This I call the old model:
http://www.unclewhiskeybreath.com/cs800.jpg
and this the new:
http://www.partysound4you.de/equipme...ey%20cs800.jpg
An 800x version is released later and is capable of driving 2 ohm loads.
There is also the newest and would be the CS800s.
http://www.kodachrome.org/salt/cs800s.gif
/Hugo
Old 15th November 2004, 11:54 PM   #5
Enzo is offline Enzo  United States
There are two basic versions. There are variations of the older one also. The newer one has the wind tunnel - a large grilled opening on the front for air - and LED meters. And the newer version is available with either a linear power supply, or in the switching power supply version.
Peavey is one of the most customer friendly companies I have ever done business with. If you email parts@peavey.com they should send back your drawings if the ones above are not what you need. Include the serial number of your amp to make sure they get the right drawing.
Also, if you need specific assistance in the repair, you can talk with one of their service engineers on the factory repair forum at www.peavey.com
Old 14th March 2007, 09:17 AM   #6
RyanW is offline RyanW  Canada
Netlist,
I am looking for a copy of the old CS800 schematic. Do you still have it on file? The amp I have is very old and the volume control is labelled 1 thru 10 (as opposed to the dB scale).
Old 28th May 2007, 03:14 PM   #7
mnow is offline mnow  United States
Send a message via AIM to mnow Send a message via MSN to mnow Send a message via Yahoo to mnow
Default CS800 schem
RyanW,
I have the older 800 schems if you still need them
Old 28th May 2007, 07:35 PM   #8
Netlist's Avatar
Originally posted by RyanW
Netlist,
I have it but with a volume control from 1 thru 12.
Keep an eye on your mailbox.
/Hugo
Old 26th October 2008, 10:33 AM   #9
Default CS-800 schematic
/Hugo
Do you still have this file? i could realy need it.
Old 27th October 2008, 08:53 AM   #10
Default Peavey CS800A schematic
Please goto http://webpages.charter.net/eastwind...ng/CS800-2.jpg
Here is the schem for the Peavey CS800 version A.
Hope it helps.
a need for an old Peavey schematic attu29a Parts 2 31st March 2006 03:04 PM
Peavey EQ-215 schematic Netlist Parts 2 8th April 2005 06:42 AM
Need schematic for Peavey 8.5c argonaut Solid State 2 11th December 2004 03:54 AM
Peavey CS800 power transistors smokinleroy Parts 1 6th April 2004 12:45 AM
peavey cs800 power amplifier bong Solid State 2 28th November 2002 07:06 AM
Page generated in 0.09977 seconds (78.17% PHP - 21.83% MySQL) with 10 queries
