Old 15th November 2004, 06:55 AM   #1
Default Distortion on Power Amp that goes away when tapped?
My Nikko 230 gets distorted until I lightly tap the back, in that area of the cooling fins, and then it goes away. I took the top off and nothing seems loose. Any ideas?
Old 15th November 2004, 09:08 AM   #2
Will need to gain access to the bottom of circuit board and look VERY closely with magnifying glass at solder joints, especially on output transistors/IC (don't know amp). You will be looking for fine circular crack in the solder - resolder it and it should work again.
Cheers
Graeme
In op-amp do not_symmetrical power supply cause distortion? ygg-it Chip Amps 3 9th October 2008 12:11 PM
Linear Power 1502IQ distortion at low volume 0ldSch00lf00l Car Audio 2 1st October 2008 05:18 AM
Adcom 5400 Power Amp Distortion - Need Help partialresponse Solid State 4 29th August 2005 03:26 AM
power cord for HP 331a distortion analyzer dhenryp Parts 8 23rd June 2005 05:27 PM
PCB Power Traces -- distortion from vias? jackinnj Everything Else 2 20th November 2004 04:50 AM
Page generated in 0.05959 seconds (75.55% PHP - 24.45% MySQL) with 10 queries
