Is it OK to add a large bank of caps outside the amp? Is it OK to add a large bank of caps outside the amp? - diyAudio
Old 14th November 2004, 10:50 PM   #1
mattjk is offline mattjk  United States
Default Is it OK to add a large bank of caps outside the amp?
I built an amp in a small case, but I want to add a couple of 82000uf caps, an addition to the 2 10000uf caps that are inside.
Are there any negatives to this? I've seen some tube amp manufacturers do this.
Matt
Old 14th November 2004, 11:21 PM   #2
quasi is offline quasi  Australia
quasi's Avatar
Default Re; external capacitors
There should be no problem with this provided you do it in a safe manner i.e. housed. Depending on the amp the voltage across the capacitors could be lethal. Make sure the capacitors working voltage is high enough.
The only concern would be whether your rectifier could handle the larger instantaneous load while these charge up so I would check this.
Place an additional discharge resistor across them too.
Cheers
Old 14th November 2004, 11:27 PM   #3
thank you for your reply.
I plan on incorporating a manual soft start switch, but for now, I leave the amp on all the time, and turning it on doesn't seem to be a problem.
Thanks!
Matt
Old 15th November 2004, 03:19 AM   #4
EWorkshop1708 is offline EWorkshop1708  United States
I'm glad I found this thread!
That just answered a question I had about the amp I just made.
I plan on having larger caps external from the PCB so they don't take up precious circuit board space. However, they will be inside the enclosure.
I guess the wires need to be thick for the amps to get the best peak current from the externally mounted caps.
Old 15th November 2004, 03:18 PM   #5
AndrewT is online now AndrewT  Scotland
Hi e1708,
Consider using thinner wires to connect the extra bank of caps into the board.
The resistance will create a CR filter and a few hundred milliohms here might better suit your needs.
Then the onboard caps should be sized to meet the short term peaks.
regards Andrew T.
Is it OK to add a large bank of caps outside the amp?Hide this!Advertise here!
Large caps Stuart Easson Swap Meet 26 25th March 2009 03:57 AM
Large Caps - Any good? jkeny Parts 5 12th August 2008 08:02 PM
Paralleling small value caps with large value PS caps xyrium Power Supplies 16 14th October 2005 04:06 PM
Where to buy large caps in Europe? Sony Pass Labs 7 8th May 2005 11:16 AM
Adding large caps? Rino odorico Everything Else 6 13th September 2002 10:16 PM
Copyright ©1999-2017 diyAudio
