And this is how it all started - Page 3 - diyAudio
Old 17th July 2002, 03:43 PM   #21
jan.didden's Avatar
Default Re: It uses stepped switches
Originally posted by gromanswe
CMOS 40193 up/down counter is remotely controlled
CMOS 4051 8-channel analog multiplexer
resistor divider
1 resistor is in series with incoming signal
where only the 8 resistors are switched to GND
the CMOS FETS works best around GND
this is repeated
twice with a buffer OP in between
to get 8x8=64 steps -1dB/step
Hmm yes that could work. Are you using R/2R ladder networks? What is the value of your series resistor? What is the ratio of your series resistor to the lowest value switched resistor?
Jan Didden
Old 17th July 2002, 03:49 PM   #22
schizeckinosy's Avatar
Default Re: About Attenuating, Volume Control.
When using some meters of Loudspeaker cable,
you get one problem. Transfering high currents
at high speeds.
When using bi-/tri-amping with monoblock mounted
next to woofers, you get another problem.
Tranfering the signal attenuated of Volume control
in centerplaced Preamp, to the Endstage.
I am interested in this tradeoff, so I started a new thread about it (long cables...) in this forum.
Cheers! Dan
Old 17th July 2002, 03:56 PM   #23
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I think that remotely controlled volume control module, right at the input of the amplifier would be the best product ever invented for audio. Lets say you are using tri-amping and you have 6 monoblocks amps. The module would be quite small (maybe the size of a computer mouse or smaller ) and it mounts directly to the input jack of the amp, the interconnect cable is connected then to the module. Then you have a remotely controlled central control console which through the remote, communicates with the modules and sets different volume levels and remembers individual adjustments as well. If you take care of source switching somwhere else you have the best passive preamp ever done. I was playing with that idea for last 10 years, somehow never realised it, maybe because I'm not a microcontroller guy.
I've also never seen it implemented. I'm glad someone else is talking about it too.
Old 17th July 2002, 05:01 PM   #24
Account Disabled
Send a message via ICQ to gromanswe Send a message via AIM to gromanswe Send a message via Yahoo to gromanswe
Default Janneman
No, 4051 only closes 1 of 8 Jfets-switch.
So only 1 resistor at the time is connected to GND.
Yes, the lowest resistor is the crushial point
when using JFETS with R-on in the magnitude 50 ohms.
To achieve a result satisfactory to your
acceptance of evnetually distortion
you have to calculate how big is R-on
variations in relation to R1+R2+Ron.
A way around that, for ultimate solution is using
DRY reed relays to switch.
This is my favorite
DSS41A05= needs some 8mA to switch
http://www.alliedelec.com/catalog/ca...s/2002/712.pdf
Old 17th July 2002, 05:05 PM   #25
Account Disabled
Default Janneman
Making a conventional 2-resistor divider.
acceptance of distortion,
A way around that, for better solution is using
Dry Reed Relays to switch.
This is my favourite
Old 17th July 2002, 05:24 PM   #26
jan.didden's Avatar
Default And this is etc
Gromanswe,
So I probably misunderstood you, I thought you had it working rather than just as an idea. I was interested in your particular choices.
As to the relays, I have posted earlier my preference for a particular type (Pickering) along with the arguments why I have this preference.
Cheers, Jan Didden
Old 17th July 2002, 06:00 PM   #27
Account Disabled
Default janneman
I have it working.
Old 17th July 2002, 08:55 PM   #28
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Wow - the best product ever invented for audio!
I guess you need to post a schematic soon.
Of course you still have the problem of the poor little low level signal from the source having to travel to the various locations.
Unless you can split up a cd player!
"The geek shall inherit the earth"
2016 S.F. Burning Amp Festival To Be Nov. 13
Burning Amp thread here on diyAudio [/B]
Old 17th July 2002, 08:59 PM   #29
Account Disabled
Default Variac
I do not claim this to "the best product" for you.
This is what I built over 2 years ago.
A friend who knows how to use CMOS logic helped me
with that part.
It is the best product I have ever built.
That I can claim.
Old 17th July 2002, 09:13 PM   #30
diyAudio Editor
Variac's Avatar
Actually, I was serious- I agree with HPotter- this is pretty cool!
help me get started Higbean Tubes / Valves 3 1st August 2007 04:09 AM
Getting started Sandy M Multi-Way 29 13th April 2005 07:34 PM
Help me get started mrlots2do Multi-Way 3 27th May 2004 08:47 PM
Getting Started CollegeGuy Multi-Way 2 25th February 2004 06:40 AM
What got you started? Vivek Everything Else 15 7th August 2002 07:45 AM
Copyright ©1999-2017 diyAudio
