My  PA-1  PRE-AMP
My  PA-1  PRE-AMP
Old 12th November 2004, 04:23 PM   #1
audio-gd is offline audio-gd  China
Default My PA-1 PRE-AMP
My PA-1 PRE-AMP is complete ,it's sound us electron tube 12AX7 of RCA .it's cooperate my XA-100 ,the sound is best.
S/N
112DB(input is not load )
Max signal voltage output
19V RMS(THD<0.1%)
frequency width
20HZ-20KHZ(0DB)
5HZ-100KHZ(-1DB)
0-450KHZ(-3DB)
תٶ
Slew rate Etc
65V/uS
THD
-105DB(1VRMS,1KHZ)
Old 12th November 2004, 04:31 PM   #2
Default The circuit diagram
The circuit diagram
Old 12th November 2004, 04:38 PM   #3
Default PA-1 and XA-1
PA-1 and XA-1,the CD player is Marantz CD16,,DAC is my builded TDA1541AS1. Sound box is my design for Scanspeak 8545K and ETON 25SD1
Old 24th December 2004, 11:28 AM   #4
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default Tell us more about your speakers
You said.
"Sound box is my design for Scanspeak 8545K and ETON 25SD1"
I would really like to build something similar, could you tell us more about your spaekers?
Old 24th December 2004, 02:18 PM   #5
Default Hi MIKET
My sound box is a two resonance type. This type can let the woof too low .
My English is too bad ,so I can not say more , but I can shoe the blue print , and you can see it .
The file is see in Coreldraw 9.0 edition .
Welcome give me some idea
Old 24th December 2004, 02:20 PM   #6
Old 24th December 2004, 02:54 PM   #7
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
My PA-1 PRE-AMP
Very impressive circuit. I am not a big SS fan but could probably live with your pre.
Old 27th December 2004, 01:51 PM   #8
The sound box's asunder circuit .
It's out off the sound box,and anear the amplifier ,but it must distance the amplifier least 30CM.
In this way , the sound is better.
Old 29th December 2004, 12:29 PM   #9
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Very good Audio-GD, put all good thing here...very good...more!
Very good...put more and more... i will be waiting for you.
very good.
thanks
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 29th December 2004, 02:42 PM   #10
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Audio-GD,
are you going to add an English page to your homepage in the future ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
My  PA-1  PRE-AMPHide this!Advertise here!
