Hello,
I've been looking for insulators for TO-264 package transistors, but can't seem to find them anywhere. Does anyone know where to find them? |
#2 |
Try Mouser Electronics
www.mouser.com |
#3 |
Nope. They don't have it.
#4 |
Correct me if I'm wrong, but I think that a T)-247 insulator is close enough in dimention to do the job.
#5 |
A TO-247 is 825x626x198 mils, and TO-264 is 1023x783x196 mils. Kind of a big difference, especially in the height.
#6 |
Digikey 3M541334-ND a lifetime supply? or sil-pad sheets
#7 |
diyAudio Moderator Emeritus
I have used these from mouser:
http://www.mouser.com/index.cfm?hand..._pcodeid=53201 The data for the 4180 pad is here: http://www.aavidthermalloy.com/produ...insulate.shtml The surface of the package is covered, and the pad is thick enough to isolate it from the heatsink. The 4170 pads are smaller, but I used them for TO-264 devices once as well: http://www.briangt.com/gallery/jeeta...ize_of_amp_016 Most of the surface is covered on the bottom of the package, and the heat transfers quite well. The 4180 pads are quite a lot bigger, and work perfect for the TO-264 IMO. -- Brian |
#8 |
Thanks, BrianGT. I think I'll use the 4180's.
#9 |
Kapton tape of the correct width does the job very nicely.
-Matt |
#10 |
I used insulators for TO-3P package on my TO-264's and they worked just fine.
You can find them at Parts Express for $1.50/10 Insulators |
| gap pad insulators | unclejed613 | Solid State | 0 | 28th March 2009 03:11 PM |
| TO-3P Insulators | EchoWars | Solid State | 30 | 6th December 2004 12:53 PM |
| TO-247 Insulators | mik | Parts | 7 | 5th March 2004 01:04 AM |
| TO-3P vs. TO-247 insulators | vsr123 | Pass Labs | 2 | 24th April 2003 09:14 PM |
| Insulators for ho-3?? | CryingDragon | Solid State | 10 | 24th November 2002 03:25 AM |
| Page generated in 0.09017 seconds (79.83% PHP - 20.17% MySQL) with 10 queries |
