Heatsinking has now become less dense!
Old 9th November 2004, 12:46 AM   #1
cunningham is offline cunningham  United States
Default Heatsinking has now become less dense!
Graphite foam.....Ahhh new research.
http://www.enme.umd.edu/~kimjh/graphitefoam.html
Old 9th November 2004, 04:21 AM   #2
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default This can be wonderfull, but i have my suspections
If your tried to use fan.... i suppose the noise will be very big....and those cavities are internal, and many not interconected in a good shape to air cross...even to air contact....if the air not move inside, only convection heat movement will work..... but how?.... having not vertical or horizontal tubes?.... Labirint.....also i am thinking if you tried to make some watter flow to cool the surface...if air cannot move well...maybe watter can move?... i suppose you will have enormous resistance to the watter flow....maybe be good enougth to use to have a good shower...if very strong and resistant, can be used to make skin peeling, or to remove dead skin from our foot...but do not seem to be too much interesting to cooling, as surface, not in contact with air in movement never worked.
I must confess i had not patience enougth to read all the text showed in the link..... because seems bad first sigth...but i can be wrong...will return to read each word.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 9th November 2004, 04:25 AM   #3
Default Now i did it...read it entirelly.... a System....may be expensive
I believe it will work...but for very special applications were the cost is not a problem...it is not only the foam....much more than a foam, a termical entire system.
Carlos
Old 9th November 2004, 04:40 AM   #4
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Destroyer:
I'm sure the developers will be glad to learn that they have your blessing.
Old 9th November 2004, 05:04 AM   #5
Default You are terrible... always flying in turns alike a hawk
And go down fast when find "the perfect objective".
You may write a book, you are too much intelligent, your sarcarstic humor is great.
You put the points and the dashes in their place.
The real meaning is the one you told...they are ..... about what i think.
I remember you humor since the first time i came here..... how is your motorcicle seat dear Bill?....... are you feeling well?.... i suggest you to replace to a bigger one....hehe
regards,
Carlos
Old 9th November 2004, 07:09 AM   #6
Thanks.
My sarcastic humor works wonders with my social life - it keeps the fleas away.
Heatsinking has now become less dense!Hide this!Advertise here!
Making a dense nonresonant material Few Multi-Way 36 7th December 2009 06:28 PM
heatsinking Ted205 Chip Amps 24 30th August 2008 08:50 AM
Question on heatsinking Hastur Pass Labs 14 5th February 2007 01:30 PM
Class A heatsinking, or heatsinking in general! NUTTTR Solid State 27 22nd January 2005 01:48 PM
Copyright ©1999-2017 diyAudio
