Hello,
I got a couple of OPA134 OPamps, and I would like to use them to build a simple amplifier. This is my first DIY project. Can you please show me schemes I can use? Thank you very much. |
#2 |
#3 |
Thank you very much!
I got couple of questions: 1. What is an audio buffer? 2. How can I turn positive to negative voltage? (48V to -/+15V) 3. C6, What does 2u2 stands for? |
#4 |
Ben. |
#5 |
2u2 means 2.2u. put the unit of mesurement where the dot goes. This helps confusion when schematics get photo copied. you can get confused and put a 22u cap in insted.
#6 |
are you intending this for a preamplifier? if yes, use a two stages with opa134 in noninverting topology with gain about 2.1 (1k +1k1), with the potensiometer between them. dont use any caps on the signal, just built a hefty power supply (like 2x4700u + 50 VA / ch + 317/337)... results can be surprising...this is what im using.. really good..dynamics, clarity and huge soundstage (627 lately).. to convert a single supply to dual you could use sth like a buf634 with a voltage divider to generate the 0V potential.. where is the intended 48v from? Using the supply of a power amp isnt adviced, and this will create problems with ground interfacing, too...
i am currently using 60,000 uF of capacitance in my preamplifier.. |
| Kenwood Basic M1 Amplifier | Rte 66 Dave | Solid State | 21 | 24th March 2012 10:42 AM |
| RCA 1972 Basic amplifier MODS | ostripper | Solid State | 102 | 13th June 2009 10:14 PM |
| Basic amplifier questions | jsd | Solid State | 2 | 23rd August 2004 10:19 AM |
| Properties of Basic amplifier | Edo | Solid State | 4 | 11th November 2002 09:42 PM |
| Basic Amplifier Question | RobPhill33 | Solid State | 22 | 6th October 2002 11:22 AM |
| Page generated in 0.07612 seconds (72.39% PHP - 27.61% MySQL) with 11 queries |
