I use WinSpice and have a question about the LM317. The National Semiconductor data sheet states that Vout = 1.25V (1 + R2/R1) + Iadj * R2. I used two different LM317 netlists from this forum and I don't understand my results.
When R1=1K, R2=0, then vout=1.313708V (close to the expected 1.25V) When R1=1K, R2=10K, then Vout=11.072751V (close to the expected 11.5V) Anyone know why vout a little higher in the 1st case and a little lower in the 2nd case? A second question is using capacitors across the incoming power and output leads as opposed to without. Without caps, the voltage has no ringing but it takes about 1 mili-second to approach vout. Without caps, the voltage has 10ths of a micro-volt ringing and it only takes about 0.1 mili-second to approach vout. I'm using the circuit for fan regulators in my computer case. Should I leave out the caps? A third question is what would cause an underflow error in myftoi() for both case of R2? |
| Transfer function. Poles not where expected | Raka | Multi-Way | 35 | 29th July 2008 01:20 PM |
| Not a lot of Amps drawn, not what I expected! | iUSERTLO72p | Car Audio | 18 | 12th January 2008 08:49 PM |
| Lower than expected output | bushroot | Solid State | 19 | 31st July 2006 01:15 AM |
| 2sa1302/2sc5200 Power Expected? | zox2003 | Solid State | 38 | 27th March 2005 08:57 AM |
| Page generated in 0.06432 seconds (68.12% PHP - 31.88% MySQL) with 10 queries |
