Finishing up a headphone DOZ, and wanting to perhaps build a full-blown DOZ for driving speakers. However, I'd like to implement current-sharing, and parallel output devices.
With an amp like this, where should the resistors in the output stage be located? I had planned on using .15 ohm or .25 ohm resistors in the collectors like so: (only one pair of outputs show, 'cause I'm too lazy to rebuild the whole thing in Visio at the moment, but you get the idea) |
#2 |
Or should they go in the emitters?
Or one in the collector, and one in the emitter?? |
#3 |
Like in the second picture, on the emitters.
#4 |
I used 8 output transistors per channel in an amp I built... i used the 2sc5200's from digikey...and i also used those transistors for the driver transistors b/c of the increased demand on the drivers. Turned out quite well. My final PS was 800va toroidal 40-0-40 that i used to get a 53-0 DC supply. Bias was set at 3 amps per channel. 300 watts of heat hehe
-Matthew K. Olson |
#5 |
I like that idea.
Also can be used as a heater too If you feel loneliness, this warm will be helpfull. You have nothing related crazy.... class A sounds wonderfull. regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#6 | |
Opinions on the resistor size? Should I use larger than 0.15 ohms? Maybe 0.22 or 0.25? |
#7 |
Thats kinda the problem...i dont' remember what size. Probably .47 ohms is what i used...but i don't really remember hehe
-Matthew K. Olson |
#8 |
Carlos, glaciers thaws. Sometimes in future will be class A amp crime
#9 | |
#10 |
I think it was like what you had in the 2nd pic...but again, that dang memory of a 24 year old haha
-Matthew K. Olson |
| Sharing current through diodes | rtarbell | Parts | 1 | 3rd April 2007 03:49 PM |
| PSU sharing grounds | neutron7 | Parts | 2 | 5th March 2005 12:23 AM |
| sharing amplification | chanvr6 | Solid State | 0 | 4th July 2004 10:09 AM |
| Sharing DAC outputs | Prune | Digital Source | 0 | 22nd January 2004 10:40 AM |
| current sharing in class AB outputs | hitsware | Solid State | 5 | 19th October 2003 05:02 PM |
| Page generated in 0.09309 seconds (83.90% PHP - 16.10% MySQL) with 11 queries |
