Old 1st November 2004, 05:11 PM   #1
aarsoe is offline aarsoe  Denmark
Default Krell KAV 250P - power setting connections
Does someone know how to connect the jumper cables for 220 or 240V for the Krell 250P preamp?
Currently mine is set to 110V and the connections are as follow.
JP1/JP6=open
JP2/JP7=Closed
JP3/JP8=Closed
JP4/JP9=open
JP5/JP10=Closed
This unit dont care about the 50Hz vs 60Hz issue, so I am only looking for the cable connections, nothing else..
AA
Old 1st November 2004, 06:29 PM   #2
K-amps is offline K-amps  United States
K-amps's Avatar
Default Re: Krell KAV 250P - power setting connections
JP1/JP6=open
JP2/JP7=Closed
JP3/JP8=Closed
JP4/JP9=open
JP5/JP10=Closed
AA
If you do a search there was a thread around setting the KAV-300iL's power to 220v. They figured it out in the end, long thread though... maybe that can help.
Old 1st November 2004, 09:20 PM   #3
Yes - saw it, however the KAV 300iL have different switches - there are only 3 of them, and this one have 5 - and they are not switches, but jumper cables..
But thanks..
Old 4th November 2004, 01:13 PM   #4
Is there really no-one out there who can help me?
You dont have to take the cover off, can be seen through the venting holes next to the power chord attachment point.
Old 14th January 2005, 06:07 PM   #5
This is my config for KAV-250p @ 240V/50Hz (Swedish)
All jumpers open, except:
JP5 / JP10 = closed
JP7 / JP8 = closed
// XyloFoam
Old 14th January 2005, 07:54 PM   #6
Thx
I acutually forgot about this thread. Found the answer quite some time ago. But thanks again..
Blown fuse when power on without connections internally hew128 Digital Line Level 9 30th August 2009 04:18 AM
Setting power amp so speakers don't blow (help a novice) drumstruck Solid State 0 29th May 2009 02:23 AM
setting bias for power FETs? bdeko Solid State 16 19th July 2007 04:41 PM
krell kas power suppy hum minh_827 Solid State 10 16th September 2005 01:44 PM
Voltage from the power transformer in a Krell KMA-100 mk1 Pinhead Solid State 5 29th April 2004 09:20 PM
Page generated in 0.09062 seconds (76.74% PHP - 23.26% MySQL) with 10 queries
