trafo outputting higher than rated Vdc
Old 1st November 2004, 01:50 PM   #1
timsch75 is offline timsch75  United States
Default trafo outputting higher than rated Vdc
I'm working on the PS of my gainclone and have a couple of CHIA YU LU (sp?) trafos that I'm running through MUR860 diode bridges. When I hooked it up and powered it, I read ~+-22Vdc. A few days later after putting snubber caps (.022mfd, 200V) across each diode, it now reads ~+-26Vdc. I'm no EE, so could someone please clue me in on what might have happened? Can caps raise the output voltage? If so, it's certainly news to me. BTW, I smelled and heard nothing indicating any problems and the voltages were steady across all four output voltages.
thanks
tim
Old 1st November 2004, 03:01 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
I wouldn't worry. Probably just mains at lowest limit on one day, highest the next.
Old 1st November 2004, 03:07 PM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
Did you have any capacitors after the bridge or were you measuring with no caps?
A difference of almost 20 % sounds a bit high for normal mains variation (I'm used to a few percent maximum).
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 1st November 2004, 06:59 PM   #4
Both times I measured there were no connections after the bridge
Old 1st November 2004, 07:05 PM   #5
blmn is offline blmn  Brazil
blmn's Avatar
Put out the snnubers and check de DC output again.
I think it has not to be with the snnubers, but...
Old 1st November 2004, 07:23 PM   #6
K-amps is offline K-amps  United States
K-amps's Avatar
Is the amplifier loading the PSU or is this a stand alone PSU? A heavy bias can lower supply rails. However if the PSU is stand alone, I'd rip out each component and see whats wrong, a 22 to 26 volt jump is not good.
Old 1st November 2004, 08:25 PM   #7
The amplifier chips are not hooked up to the PSU yet. I just checked the voltages coming out of the bridge with it hooked up to nothing.
The thought of pulling off those 16 caps off to test is a bit of a drag. It was a minor PITA soldering those p-t-p across the mur860's.
Old 1st November 2004, 08:54 PM   #8
cunningham is offline cunningham  United States
Rated voltage is at rated current. If the transformer is not loaded, you will see slightly higher voltage.
Old 1st November 2004, 09:02 PM   #9
I made the same measurement before without snubber caps and without load and got +-22Vdc. I have another set of trafos that measure +-18Vdc at the bridge without load, which is its rated voltage. So two out of three measurements saw no significant increase over rating without load. What would be different here?
Old 1st November 2004, 09:11 PM   #10
Tim__x is offline Tim__x  Canada
If there is no load snubbers act as tiny little supply caps. Put a very light load on the psu, 47-100k and then measure it.
trafo outputting higher than rated VdcHide this!Advertise here!
Using higher rated ouput transistors?? tgferg67 Solid State 11 6th January 2007 07:14 AM
Subwoofer not outputting bubbers214 Car Audio 4 5th March 2006 11:56 AM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 05:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 07:40 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
Copyright ©1999-2017 diyAudio
