Old 1st November 2004, 10:32 AM   #1
Question Leach Amp PSU Capacitors
Hy to all,
I have some questions about Leach Amp PSU
I intend to build this amp with 32900 uF per rail, the result of 7x4700 uF capacitors wired in parallel ...
Is this a problem ? In other words is the same thing if I use 10x1000 uF capacitors always wired in parallel instead of one single capacitor rated at 10000 uF ?
One more question ? The toroidal transformer from Victoria Magnetics has 6 Amps on each winding I mean 6+6 = 12 Amps
or 6 Amps represent the total current 3+3 = 6 Amps ?????
Please help ...
adrianbodor,
Old 1st November 2004, 10:58 AM   #2
dutch diy's Avatar
Send a message via ICQ to dutch diy
1: It's not quite the same having multiply caps in parallel or using one.
The advantage of using multiple parallel caps is a reduction in internal resistance (ESR) which is very nice. So 7x 4.700 uF could work out better than a single 33.000 uF cap, unless the 4.700uF caps have a very poor ESR.....
2: 6 amps on each winding gives 12 amps when two windings are placed in parallel, but just 6 amps when used in series. Most of the time windings are used in series to get a positive and a negative power supply, with 6 amps thus available.
Succes....
Old 23rd November 2004, 10:37 AM   #3
Is there any diference between using Wima film capacitors MKS 2 instead those listed by Dr. Leach ... i mean those caps that are film based ...
0.1uF/100V
0.1uF/50V
0.01uF/50V
If I use these tree values in Wima caps MKS 2 version at 100V all of them
would make any diference ?
I don't have the posibility to buy at 50V only at 100V ...
pls help ....
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
Leach bipolar capacitors pinco Solid State 20 13th June 2008 10:06 AM
which capacitors to use in leach??? Wagener Solid State 1 5th May 2004 04:10 PM
resistors and capacitors in leach amp Wagener Solid State 3 30th April 2004 10:42 PM
Capacitors for the Leach ? Flavius Solid State 3 2nd June 2003 09:07 AM
Page generated in 0.07521 seconds (70.76% PHP - 29.24% MySQL) with 10 queries
