Old 31st October 2004, 11:48 PM   #1
Stubb is offline Stubb  United States
Default Reducing preamp/amp voltage gain?
The preamp/amp combo in our system consists of an Adcom 750 preamp and Bryston 4B ST power amplifier. The overall gain of these two components is fairly high, so the volume control rarely moves more than a few degrees from zero. This makes use of the remote difficult: a single push usually goes from "too loud" to "too quiet" and skips "just right."
Any thoughts on reducing the gain of this combo? The warranty on the Adcom has long since expired, but I'd rather not mess with the Bryston. The easiest solution would appear to involve building a fixed passive attenuator between the preamp and amplifier. Are there any rules of thumb for choosing the impedance of such a component to avoid trouble? The output impedance of the Adcom is listed as < 600 Ohms (< 1200 Ohms balanced), and the input impedance of the Bryston as 50k Ohms (20k Ohms, balanced). They're currently hooked via the unbalanced connection. A quick test with a VOM indicates that 10–15 dB of attenuation should do the trick.
Thanks in advance for your suggestions.
Andreas
Old 1st November 2004, 08:35 PM   #2
Tim__x is offline Tim__x  Canada
No real rule of thumb, it's weaker than that, maybe 'rule of pinky'
Keep the resistors high enough that you don't strain the preamp
keep the resisitors low enough that you don't put excess noise into the system.
May I reccomend a 10k and 3.9K with the 3.9k being the one tied to ground. In your particular setup this will give you around 12db of attenuation
reducing system gain slr 5000 Solid State 28 30th August 2008 10:05 AM
Reducing gain on Audible Illusions M3A no xo Tubes / Valves 4 27th August 2007 05:27 PM
Reducing the gain - LM3875 and alternative diodes :) quickshift Chip Amps 11 29th October 2005 10:00 AM
Reducing the gain with an inverting gainclone Bricolo Chip Amps 10 1st December 2003 04:58 PM
Reducing gain on Bride of Zen? Yochim Pass Labs 12 13th September 2002 02:18 PM
Page generated in 0.05953 seconds (70.40% PHP - 29.60% MySQL) with 10 queries
