UR comments required
Old 6th July 2002, 08:57 PM   #1
palesha is offline palesha  India
Default UR comments required
This is a old circuit of 80's. My friend has assembled by replacing few devices. He is happy with the performance.
He replaced
1) BC 546b matched for 2N 2919
2) BC 546b for MPSA05
3) bc 546b for BC 109
4) TIP 142 for TIP 141
5) TIP 147 for TIP 147
I wish to assemble the amp myself. I want suggestions for modification or changes to be carried out in the above mentioned circuit for better quality & higher output.
Mahendra Palesha
Old 7th July 2002, 03:51 PM   #2
paulb is offline paulb  Canada
Is there any particular reason you want to build this exact amp? There are other designs that may be easier and/or better. Check out www.sound.au.com for some.
I build an amp like this and had problems adjusting the bias correctly (it kept running away). I think the Darlington output transistors were part of the problem, but it was probably mostly the thermal coupling to the bias network wasn't right.
Old 7th July 2002, 04:01 PM   #3
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Add a capacitor 100nF minimum from TR6 base to TR7 base.
GP.
UR comments requiredHide this!Advertise here!
Help required xyz9915 Power Supplies 5 8th October 2008 03:35 PM
help required with p3a Mark25 Solid State 5 16th November 2006 12:41 AM
Help required ! LarryN Parts 2 19th July 2004 02:05 AM
Help required martioz Swap Meet 3 2nd February 2003 04:42 AM
amp required b.m.turner Solid State 4 13th November 2002 01:37 AM
Copyright ©1999-2017 diyAudio
