Old 31st October 2004, 04:30 PM   #1
Default hum on preamp phono output
hello
I have hum on my phono preamp output .
When connecting my turntable , hum is quit big and reduce 90% when connecting aplifier earth .
I try to make a direct wire from cartridge to phono output , same problem , i change the cartridge , same problem , so I suspect the phono output but I do not know many in electronics .
When thre is no connection on the phono output thre is still hum .
My preamp is 20 years old with component like :
NE 5524 AN
B32520 u22K100
itt 25V 47 uf.
Can someone give me some help , should i chnage the itt caps 47 uf ?
alos if i can upgarde it , the phono is on a single card !
thank's
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono preamp wombil Solid State 5 21st May 2008 11:59 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Which phono preamp ? yagoolar Tubes / Valves 5 26th January 2005 10:50 AM
Phono Preamp. victor Pass Labs 0 24th October 2001 07:11 AM
Page generated in 0.06697 seconds (68.35% PHP - 31.65% MySQL) with 10 queries
