JLH problems
JLH problems
Old 31st October 2004, 03:04 PM   #1
serosmaness is offline serosmaness  United States
Default JLH problems
Hello everyone. I am wondering if one of my regulators are bad?
I have + 22v and -22v untill I connect the power supply to the amp. When I turn the amp on I still have +22v but the neg goes to 0v and then goes to -5v when I switch the amp off.
I have been checking the amp board for the last 3 days. I can't find any faults.
Thanks Steve
Old 31st October 2004, 03:41 PM   #2
Panelhead is offline Panelhead
Default Re: JLH problems
Thanks Steve
Sounds like the neg rail reg is shutting down. Try checking the impedance to ground from the power input with the power supply disconnected. If something is shorted it should show up hitting it with a VOM.
George
Old 31st October 2004, 04:20 PM   #3
I checked for a short on the amp board without the ps connected between the Neg and ground and it showed open. With the PS connected it showed around 3K .
Thanks for the reply.
Steve
Old 31st October 2004, 05:45 PM   #4
Geoff is offline Geoff  United Kingdom
Hi Steve
No answer for you as yet (too little information on which to work) but a few questions.
What regulators are you using and in which circuit arangement?
Which version of the JLH have you built and what is your intended quiescent current?
Have you set the quiescent current control preset to give the minimum Iq prior to conecting the power supply?
Have you tested the power supply using a dummy (resistive) load?
Geoff
Old 31st October 2004, 10:50 PM   #5
Hi . I am using the circuit on page 4 fig 2 The Final Circuit without the feedback cap C-4. I am using the lm338t regs. I have the iq set low. I read only .114v acrossR10
I found Q.2 shorted to the heatsink via the screw. Now I have +22v and Neg 22v but the - side drops out after a few seconds but when I have the -22 I have 7v at the speaker output.When the -22 drops out I get 22 volts out.
Thanks Geoff
Old 1st November 2004, 06:42 PM   #6
I have it working so far. I will set the quiescent current at 2 amps.
Serosmaness.
Old 1st November 2004, 08:33 PM   #7
Steve
Glad to hear the good news. I was just about to reply to the post you made yesterday, but now you have saved me the trouble.
As a matter of interest, what was the cause of the problem?
Geoff
Old 1st November 2004, 10:10 PM   #8
Thanks Geoff. I eliminated the 7 volts with the dc bias pots.
The regulator was dropping out because I had the Iq set to high and I had not put a heatsink on the regulator.
Is .115V drop across r10 .33ohm enough Iq. Does this equate to a Iq of 3.4 amps?
Thanks again.
Steve
Old 1st November 2004, 11:35 PM   #9
0.115V across R10 would give an Iq of 0.348A which is far less than the 2A you are seeking.
Old 2nd November 2004, 12:30 AM   #10
Thank you. I thought that I was off by a decimal point so I asked.
I think that I will need a much bigger heatsink since the one that I am using gets warm with .34a Iq.
steve
JLH problemsHide this!Advertise here!
GFA-565 problems ben62670 Solid State 5 14th August 2008 07:36 AM
HK AVR 335 Problems utjay2008 Solid State 0 21st October 2007 03:26 AM
Nak dvd-10s problems MadMutt Digital Source 8 26th March 2007 11:06 AM
Sub Amp Problems Thanks! crippledchicken Solid State 2 10th January 2007 07:17 PM
RFI problems laz Solid State 3 21st February 2004 08:06 AM
Copyright ©1999-2017 diyAudio
