JLH problems
JLH problems
Old 2nd November 2004, 01:14 AM   #11
chris ma is offline chris ma  Canada
chris ma's Avatar
Default Size matter
If you are aiming for 2A the heat sink should not be less than 2 pound in weight per output transistor in order to keep the heat sink below 60 degree C at room temperature of 25C without using a fan.. do over kill here and good luck with your project...
Chris
Old 2nd November 2004, 06:17 PM   #12
serosmaness is offline serosmaness  United States
Thanks for the info.
If I loose a rail I will end up with 22v at the speaker?
Thanks again.
Serosmaness
JLH problemsHide this!Advertise here!
GFA-565 problems ben62670 Solid State 5 14th August 2008 06:36 AM
HK AVR 335 Problems utjay2008 Solid State 0 21st October 2007 02:26 AM
Nak dvd-10s problems MadMutt Digital Source 8 26th March 2007 10:06 AM
Sub Amp Problems Thanks! crippledchicken Solid State 2 10th January 2007 06:17 PM
RFI problems laz Solid State 3 21st February 2004 07:06 AM
Copyright ©1999-2017 diyAudio
