Mic preamp problem
Mic preamp problem
Old 29th October 2004, 12:14 PM   #1
kimarin is offline kimarin  Norway
Question Mic preamp problem
Hi . I buildt this mic preamp, and I loved it. sound very open as the author said. I mounted a jack input to the preamp, so i could use a bass and a guitar on it with a 5k6 ohm resistor i series (stole the idea from a mackie vlz1604 schematic). This sounds nice, except for the kind of a ground noise when I'm not touching the strings on the guitar. Seems like a ground problem. Anyone have a clue how to fix this problem ?
http://www7.taosnet.com/f10/ssmicpre.html
Cool preamp
Old 29th October 2004, 10:11 PM   #2
moamps is offline moamps  Croatia
Output from a guitar pickup is usually unbalanced and high-ohmic. If you wish to connect the guitar to your microphone preamp, for best results you should use a di-box (or a microphone step-up transformer reversely connected). To direct connect the guitar pickup to the preamp, connect "3" and "1" together, replace R3 with 100k, C3 with 10pF and omit C1 and R1. Signal input is pin "2".
Milan
Mic preamp problemHide this!Advertise here!
P88 Preamp problem Curioprop Solid State 5 17th July 2007 03:01 AM
26 preamp problem NickC Tubes / Valves 7 13th February 2006 02:12 PM
preamp ps problem Briney Tubes / Valves 12 18th November 2005 01:21 AM
Need help w/ NAD preamp problem Jim B Solid State 13 3rd May 2005 03:41 PM
X2 preamp problem... audionuts Pass Labs 1 28th October 2004 03:28 PM
Copyright ©1999-2017 diyAudio
