can i get an amp?
can i get an amp?
Old 29th October 2004, 08:07 AM   #1
radiohead is offline radiohead  United States
Send a message via Yahoo to radiohead
Question can i get an amp?
Hey I a couple of questions.
#1 I have a set of 2 150 watt speakers running from the same connection line,do i need to hook an amp up to get optimal preformance?
#2 Do I need a single 150watt amp or do I just need a single 300watt amp?
#3 If possible could i get one of you guys to build me an amp?Ill pay for the parts and labour.
thanx alot for reading this
Old 29th October 2004, 01:46 PM   #2
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
can i get an amp? Send a message via Yahoo to vdi_nenna
Why do you think you couldn't do it yourself?
#1. Do you have 2 speakers running from one amp?
2#. Is this setup for a PA system\DJ or audio reproduction system?
3#. What type of speakers are you using? IS this a stereo setup you are looking to make?
Vince
Old 30th October 2004, 07:49 AM   #3
Default answer
#1 no the speakers arent running off an amp at the moment.
#2 its a car stereo system
#3 the speakers are roadmaster 6 inch subs "very good speakers they just arent getting enough juice" and i guese its stereo :P
im new to all this diy audio stuff,thats why i dont think i can do it lol.
im just looking for sugestions and a little help with setting it up .
Old 30th October 2004, 07:15 PM   #4
cunningham is offline cunningham  United States
I think this thread may belong in the car audio section...but anyway, if you are running these speakers off of the head unit, I doubt if it can drive them. You should use a seperate low pass filter + amp. There is more than one way to wire them, but as for starters, you want to choose an amp that is not too powerful. For good sounding results and longer life, don't drive the speakers much more than 60% - maybe 70%(depends on brand or quality) of rated power because the diaphragm movement will no longer be linear. Also you can wear out the reflex & spider. I suggest buying an amp with as much or slightly less max output than what the speakers are rated and turn the amp gain to about 60% power. This way the amp is not working super hard(less THD) and the speakers will last longer.
Old 30th October 2004, 09:26 PM   #5
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
its much harder to make car amps,u should find someone that will make one for u in the US
Old 30th October 2004, 10:07 PM   #6
paulb is offline paulb  Canada
It's WAY cheaper to buy a car amp than build one. Even if the labor is cheap.
Old 31st October 2004, 07:32 AM   #7
Talking thanx
Thanx for all your suggestions and help guys you can be assured that it is greatly appretiated
can i get an amp?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
