The smallest PCBs I have ever made. One constant current source and one voltage reference. Details can be found on this page.
If anyone can think of a way to make the current source variable by only one resistor without compromising the performance, I'm all ears...
https://mrevil.asvachin.eu/ |
#2 |
Ahhh surface mount...tiny
This is one way I too have found to make a complicated circuit fit on a small board. Because you don't need lots of current for things like bias current sources, switches and other circuit controling features, SMD's can be used and save lots of space...if you can solder the small parts without going crosseyed! They are a pain to change out sometimes for when you screw up and use the wrong part. |
#3 |
I first saw it done a few years ago when I disassembled an old receiver and saw it had separated out quite few circuits onto small daughterboards made with SMT components.
Since then I've tended to try to do the same, but every time I need to solder or desolder things I vow never to use SMT again!
#4 |
The best way to make a constant current device in ou r line of work, is to use a JFET, gate to neg terminal and a variable resistor from source to neg terminal, in case of a N fet. drain is positive terminal. There are a bunch, not so big nowadays of JFETs, out there. All of these have their own geometry rendering them different parameters. My favourite is is siliconix J201, pulling dowm 0.5mA approx at Vgs 0V. This is a really low noise maker, sounding very uninteresting to Linn ears, ie extreme low distorsion and broad bandwidth. In differential amps they need to be matched, but that is a walk in the park given you buy at least 25 and match them to Vgs at a certain Id. They really sound nice, soft and clear. And JFets are sturdy, they don't have fragile oxide layers that are punctured by a few dozens of volts. they can take abuse like a BJT. Actually they were invented long before the BJTs. Use them, you will like them. See siliconix, homesite for data and tips, for these underdogs of modern sound amplification. They are also useful for switching analog signals, where their sturdiness comes in handy. Excuse me for linguistic errata, since we had a somewhat wet dinner to night.
Andreas |
#5 |
Where are you going to get a transistor with an Hfe of exactly 315.3? Ditto what the last guy said: a JFET or cascoded JFET will make a spiffy current source, and they come in handy 2-terminal packages.
#6 |
The voltage reference is NOT a reference, it is a thermometer. The cirquit is called Vbe multiplier, and is used in supplying a variating bias to power amps that keeps track of temperature. Temperature is one great big evil when it comes to making DC stable cirquits, and this cirquit is not the answer to that. If you don't believe me invest in a breadboard and measure your reference voltage, then pinch the transistor whith your 37 C body and notice the refreence change, on a dinky DVM. You will notice that this is not what would be called a reference in any sense of the word. Better try with a bandgap ref or a buried zener LM399.
There are dozens of refs out there with temp-dependicies of 10ppm/ K. Andreas |
#7 | |||
#8 | |
W.r.t. constant current source, keep in mind that your circuit has two stable current settings. One is the one you wanted, the other is the zero current condition. These kind of circuits may not start up. In integrated circuits you often see a kind of start up current injector forcing a small current into the circuit, after stabilizing the current the injector is blocked by changing DC conditions of the current source circuit (e.g. a diode that passed the injector current is becoming reverse biased after start up). To make the circuit variable with one resistor, just replace the top or bottom current source with a current mirror. But also then the zero current condition can happen. Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#9 | ||
#10 |
I can see too much people discussing theories, and very feel people doing really diy things.
I feel happy to see that some can do it themselves, that some have the good and old real spirit. My deep and sincere congratulations regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
| FS: Aleph-X PCBs , NIGC PCBs , OPA541AM OpAmps | e.lectronick | Swap Meet | 22 | 4th March 2009 07:38 AM |
| Tiny, tiny DC-DC converter | jackinnj | Power Supplies | 1 | 28th June 2006 07:03 PM |
| any good tiny tiny tweeters? | THOR | Multi-Way | 18 | 28th June 2004 06:42 AM |
| Tiny amp | lifeonmars | Pass Labs | 4 | 12th December 2003 09:13 AM |
| Page generated in 0.12435 seconds (80.36% PHP - 19.64% MySQL) with 11 queries |
