Old 28th October 2004, 04:11 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Heatsinking ???'s Pt 2 Mr. Pass!!!
Ok, i was browsing a classified board and found a nice Threshold s350e Amp for sale and in looking at the photo's i noticed an interesting heatsink arraingment that brought me back to my original question i posted here some time ago....
If you look at the attached photo. you will see that the TO-3 output transistors are mounted with the tops of the cans away from the outside of the heatsink on a plate of some sort that mounts to the large external heatsinks. presumably with the wiring is between this plate and the heatsinks.
Now in my previous post, i asked why i couldnt mount my transistors to a flat plate bolted between 2 large heatsinks.
So i am curious how this was done in the 350e
Mr. Pass if you have a moment...
Zero
Old 28th October 2004, 04:24 PM   #2
SmarmyDog's Avatar
Mr. Zero:
I would think that as long as the trace / wire lengths were kept very short, either way would work. I only post this stab at an answer because I have been informed that Mr. Pass is very busy working on an imprtant new project and may not be available for a speedy reply to your post.
-Casey Walsh
Old 28th October 2004, 06:13 PM   #3
The one and only
Nelson Pass's Avatar
Whenever you are mounting TO-3's on a big flat plate and then
attaching heat sinks to that, there are 3 ways to go that I have
commonly seen:
1) Mount the heat sinks with a gap between the heat sinks which
leaves room for the transistor can to mount from the outside of
the amp.
2) Make a set of spacer bars which create a gap between the
big flat plate and the heat sinks. This spacer must carry the
heat from the plate to the sinks.
3) Use a big extrusion which has the gap of (2) molded into it.
Threshold uses #2, and PL uses #3.
Old 28th October 2004, 06:26 PM   #4
Audio Junkie
Zero Cool's Avatar
IS it possible to have too large of a heatsink for mosfets? or is it ok to go with the biggest heatsinks you can find?
I understand they need to be rated in c/w at least large enough for said design, but is there such a thing as having too big a sink?
Are there detrimental effects in doing so?
Ie: if we had a 20 watt class A amp and we mounted the the Mosfets to a piece of extrusion being 4' long 12" wide with 3" deep fins, or soemthing else thats way overkill for said design would there be detrimental effects???
Zero
Old 28th October 2004, 07:43 PM   #5
The one and only
No.
Old 28th October 2004, 07:48 PM   #6
Audio Junkie
Zero Cool's Avatar
Good! thats what i thought
Zero
Old 28th October 2004, 09:21 PM   #7
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Default spacer plate
would it not be possible to mount the output devices straight to the spacer plate, and isolate the plate from the heatsinks ?
The thermal resistance from the Fets to the spacer would be significantly lower, the heat taken much faster to the heatsinks.
Given a large contact area of the spacer plate to the heatsinks the area of the isolation would be of the same order, creating a small thermal resistance.
Silicon sheets of ample dimensions are available.
Leaves the question of the effects of a potential on the spacer plate ?
jacco
heatsinking Ted205 Chip Amps 24 30th August 2008 08:50 AM
lm4780 heatsinking... morpheus82 Chip Amps 14 21st February 2007 01:10 PM
Class A heatsinking, or heatsinking in general! NUTTTR Solid State 27 22nd January 2005 01:48 PM
LM4780 Heatsinking jackinnj Chip Amps 3 5th January 2005 06:00 PM
Heatsinking Questions Zero Cool Solid State 11 20th October 2004 02:54 PM
Page generated in 0.09141 seconds (78.93% PHP - 21.07% MySQL) with 11 queries
